High Voltage A On Secondary Side Of Trans - HVAC - DIY Chatroom Home Improvement Forum
Old 10-09-2012, 10:25 PM   #1
high voltage a on secondary side of trans
I heard this could happen, but have never seen it. The only way I can see this happening is the secondary winding was touching the primary. The trans was used but it said good on it, so I didnt think about ohming it out. Has any one ever seen 100V on the secondary side of a 24V trans? And yes I took secondary side out of the circuit.
hvactech54 is offline   Reply With Quote
Old 10-09-2012, 10:32 PM   #2
Missouri Bound's Avatar
Sounds like you already have it figured out.
Do you want it your way or the right way?
Old 10-09-2012, 10:37 PM   #3
so does that mean you have seen this. Did it trash your fan relay? Im not sure why I just have a hard time believing this could happen.
Old 10-09-2012, 10:39 PM   #4
Lucky it's only the relay you lost. Thermostat, circuit board etc. are all vulnerable to a line voltage surge.
Timing for rebuilding of side entry: Help! navi_jen Remodeling 0 06-16-2010 11:02 AM
Solve this one (takes some thought). bernieb Electrical 23 03-28-2010 09:40 PM
A/C low voltage hook up for a secondary electric edison meter drewfoley HVAC 3 07-13-2009 08:12 PM
Running a secondary high pressure line Randell Tarin General DIY Discussions 6 02-18-2008 12:39 PM
Low voltage in same box as high voltage? mpedrummer Electrical 2 02-28-2007 12:49 PM
