Old 11-01-2008, 12:01 AM   #1
High temperature pipe insulation
I am frying my insulation on my solar hot water system even though it says it is for high temperature. It is the polyurathane insulation.
Is there another insulation I can use that will handle 220 F maximum temperature?
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 11-01-2008, 06:37 AM   #2
An old Tradesmen
Fiberglass pipe insulation.
Works on steam.
Old 11-01-2008, 10:55 AM   #3
the pipe master
protechplumbing's Avatar
Armaflex makes a high temp insulation. It can't remember the name. Google it.
protechplumbing is offline   Reply With Quote
Old 11-01-2008, 10:59 AM   #4
the pipe master
You can use "Great Stuff" foam in a can. It goes up pretty high and has outstanding R-value. The down sides are: It takes FOREVER to put on, it looks shoddy, and you can't expose it to UV. It will turn brown and brake down if exposed to sunlight. I've heard it can be painted with a UV rated paint that is breathable.
Old 11-01-2008, 12:13 PM   #5
Well this is out then cause the whole thing is out side in the high desert sun and with the altitude and over 300 sun days a year it would be difficult to cut out the UV rays.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Pipe insulation: Foam, Rubber, Other? IckesTheSane Plumbing 36 10-29-2011 09:31 PM
Pipe Insulation: Foam or Rubber? EE playing with HVAC HVAC 2 11-01-2008 02:35 AM
Sweating windows big daddy-o General Discussion 15 01-06-2008 03:41 PM
high tech insulation joe beer Building & Construction 7 06-28-2007 08:17 PM
