High Side Line Freezing - HVAC - DIY Chatroom Home Improvement Forum
Old 06-10-2011, 09:15 PM   #1
high side line freezing
what is causing high side line to freeze
lilbizzib is offline   Reply With Quote
Old 06-10-2011, 09:53 PM   #2
Rewards Points: 6,652
Not enough to tell you, but a guess is clogged A-Coil.
Old 06-10-2011, 09:54 PM   #3
Rewards Points: 150
Your sure it's the discharge line?
Is the bigger insulated line freezing? or the smaller un-insulated line?
If it is indeed your smaller discharge line sounds like you have a restriction somewhere causing the freon to flash off.
If it's your suction line, it could be a variety of things from a dirty filter to improper freon charge.
You need to give alot more information for the hvac guys on here to give you a proper guess.
alecmcmahon is offline   Reply With Quote
"smooth" side on hardie backer amakarevic Building & Construction 2 04-12-2011 11:43 AM
Side windows and proximity to lot line Magmo Building & Construction 3 03-24-2011 01:50 PM
Timing for rebuilding of side entry: Help! navi_jen Remodeling 0 06-16-2010 11:02 AM
Laser line digital level with high resolution DIYFREEMAN Tools 0 05-16-2010 10:53 AM
high pitch noise coming from oil line pingers7 HVAC 2 11-29-2006 08:41 AM
