High Pressure Switch On-of, On Off - HVAC - DIY Chatroom Home Improvement Forum
Old 12-10-2010, 06:17 AM   #1
High pressure switch on-of, on off
2 year old Trane heat pump--When in heat mode the high pressure switch shuts outside unit off,restarts in 10-15 seconds and repeats 3-5 times. Tech came out and diagnosed a faulty t-stat. New t-stat eliminated problem for 4 days but now it's doing the same thing again. Tech said pressures were right on , so any ideas. Unit is spotless,coil looks new,airflow around unit is clean
TURBOBUG is offline   Reply With Quote
Old 12-10-2010, 12:14 PM   #2
HVAC / Plumbing
sounds like a restriction in the system causing high pressure
kenmac is offline   Reply With Quote
low pressure water to mix into high pressure iancan Plumbing 1 03-22-2010 11:09 AM
Comfortmaker RPJ II Pressure Switch hansolos HVAC 3 02-24-2010 07:50 PM
Furnace Pressure Switch bigmatt HVAC 10 09-03-2009 07:25 PM
Well Pressure Switch Location dshcs Plumbing 4 02-05-2009 10:04 AM
New Pressure Switch -- low water pressure chach Plumbing 4 01-18-2009 10:50 PM
