High Pressure Line (not Hot) - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-26-2011, 08:13 PM   #16
I'm Your Huckleberry
Rewards Points: 2,270
Originally Posted by JJboy View Post
Infra red should be ok
Nope infrared retracts light.
Doc Holliday is offline   Reply With Quote
Old 07-26-2011, 08:15 PM   #17
JJboy's Avatar
I know clamp is better....but he has only that
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
The Following User Says Thank You to JJboy For This Useful Post:
Doc Holliday (07-26-2011)
Old 07-26-2011, 08:20 PM   #18
Refracts.
Old 07-26-2011, 08:25 PM   #19
It just seems on a hot day, 95'f+ , the a\c , can't get the temp. down below 73'f.
If I try to make it colder in the house the a/c runs for ever,and never really gets colder. 73'f in the house seems to be the magic number.
Anything lower and the a/c runs forever.
When its at 73'f , a/c runs for about 15 minutes, then thermostat shuts it off. Then it turns back on maybe 10 minutes later, and runs for another 15 minutes. The unit is 21 years old.....Heil (not sure of BTU/ton)
Its been this way for awhile now.
But it seems humid in the house at 73'f.
My friend had a 4ton unit put into his house, and at 73'f in his house its cold in there. Everything you touch in his house is ice cold. Everybody complains it feels colder in his house then 73'f.
I would like my house to feel that way.
I will try to post a picture of the charts inside the unit outside ,
maybe it will show you the ton/or btu's
gixxer1000 is offline   Reply With Quote
Old 07-26-2011, 08:33 PM   #20
Pictures of the service charts in unt outside.
http://www.freeimagehosting.net/683be
http://www.freeimagehosting.net/3d740
Old 07-26-2011, 08:39 PM   #21
Your system is working decently for so old. Is this a new problem at these outdoor. Temps?.
Old 07-26-2011, 08:40 PM   #22
JJboy's Avatar
Your house insulation is not so good as your friend
gixxer1000 (07-26-2011)
Old 07-26-2011, 08:42 PM   #23
2.5 ton
The Following User Says Thank You to Doc Holliday For This Useful Post:
Old 07-26-2011, 08:47 PM   #24
What's the. lf2pe2yyp Condition. Of the condenser
Old 07-26-2011, 08:52 PM   #25
An old Tradesmen
Rewards Points: 6,132
The liquid line should not be cooler then the outdoor temp. that indicates a problem.
Old 07-26-2011, 08:53 PM   #26
I try to clean it frequently and maintain it...I'm an electrician by trade but know nothing when it comes to hvac to properly size it up.
The unit has been this way for as long as I could remember.
The installer actually screwed the install up. He put in a return line that was only 10" big. He never came back, to finish up changing it. So I installed a 20" return pipe and a 24"x24" register.
The feed coming out the unit is like a 16" pipe then reduces down to like a 12" or 14" pipe after about 10ft with 9 - 6" flex pipe coming off to the registers
Its a bi-level house built in 1976 with only the top floor cooled in the summer.
9 working registers in the ceiling.
I just wanted to see if I could get this to cool more.
And I was thinking about replacing the unit because of it age.
I was thinking about going with a bigger unit, but I know bigger isn't always better. I need to figure out on how to proper size the house for the proper ton's.
Old 07-26-2011, 08:54 PM   #27
SAY WHAT ???
Old 07-26-2011, 08:56 PM   #28
Thats why I was asking the question in the first place..my thoughts were the same...I thought it should be hotter, just like all the other units I looked at ?
Old 07-26-2011, 08:57 PM   #29
Typing from. My cell. Sorry
Old 07-26-2011, 09:00 PM   #30
JJboy's Avatar
The temperature of the high line (1/4") was 76'f before the valve.
The temperature of the high line (1/4") was 109'f coming out the compressor.
LL Temp is 109F ......outside 87F
ac not cooling, suction line freezing, suction pressure in "Retard" GetYourShineBox HVAC 7 05-26-2011 10:01 PM
lennox xp15 high pressure fault code GEAF HVAC 10 03-11-2011 09:44 PM
High pressure Shower Head Carloscda Plumbing 9 06-18-2010 01:50 AM
Running a secondary high pressure line Randell Tarin General DIY Discussions 6 02-18-2008 12:39 PM
