High Pitched Tone From Boiler? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-26-2006, 02:38 AM   #1
Rewards Points: 269
high pitched tone from boiler?
A loud and high pitched noise suddenly started coming from my parentís mechanical room. I have a very hard time trying to tell where it is coming from, although I believe it is from the boiler (we have hot water heat). The only other thing in the room would be a hot water heater, but the sound if definitely louder by the boiler. The boiler appears to be functioning normally, with gauges indicating normal temp/pressures.
The noise is loud enough to be heard anywhere in the basement, and is very high pitched (my father canít hear it, but both my mother and I can). It is also very uniform in intensity and pitch. It almost sounds like tinnitus. It has persisted without change for about a day.
The noise persists when I cut power to the entire room, so it does not appear to be electrical.
Any thoughts about what this could be and how much it should concern me?
LanterDan is online now   Reply With Quote
Old 09-26-2006, 05:05 AM   #2
is this a steam boiler or hot water baseboard with a circulation pump?
redline is offline   Reply With Quote
Old 09-26-2006, 12:13 PM   #3
Rewards Points: 269
hot water w/ circulation pump
Old 09-26-2006, 07:36 PM   #4
Is the noise present when the burner is off?
How old is this unit?
Is it vented thru a chimney or other?
Old 09-26-2006, 08:40 PM   #5
Rewards Points: 269
The sound is indeed present even with the burner off. The boiler is over 50 years old. It is vented through double walled pipe up a wood frame chase (was orgiannly a chimney, changed about 12 year ago).
Home oil boiler furnace jmb HVAC 5 03-28-2007 08:03 AM
Air in boiler / Over pressurizing Tmb9862 HVAC 12 01-11-2007 02:22 PM
Steam boiler corrosion problem franklopes HVAC 4 11-09-2006 09:02 PM
Whine from a boiler pump? formarley HVAC 2 09-26-2006 08:56 PM
