Originally Posted by SKIP4661
Typically the inducer motors have sealed bearings. If the motor is squealing it is time for a new one. You can probably find a motor but getting the wheel off is almost impossible without damaging the wheel.
Inducers are usually sold as an entire assembly which makes it easier to replace.
I replaced the inducer. I believe I put everything back the way it was (pvc pipe, screws , electrical and 2 hoses), but it starts up but never produces heat. It shuts down and gives a code of "pressure switch open, should be closed" (3 flashes). Any ideas?
