High Low Side - HVAC - DIY Chatroom Home Improvement Forum
Old 06-01-2011, 02:09 AM   #1
Rewards Points: 150
high low side
hey I have an old ruud, that I thought was out of freon. I added les than a pound and the low side shot up to 90 PSI. the high side was about 200. I could not figure out what was going on so I recovered all freon and pulled it down to -30. I thought maybe there was air in the lines or something. I put back in 2 pounds on a factory charge of 3.6 pounds and the low side is 100 PSI. The outside temp was 85. The compessor is working right since I am getting 100. the suction line temp stayed at 84 no matter what I was doing. I did noticed when I took the fan off the lines inside were very hot and so was the compressor. I cleaned the outside coils, but that didnt help.
Im thinking maybe blockage on the suction side?
Any clues?
wetbar is offline   Reply With Quote
Old 06-01-2011, 06:44 AM   #2
Rewards Points: 1,214
Bad valves in compressor need to replace the compressor.
COLDIRON is offline   Reply With Quote
Old 06-01-2011, 07:36 AM   #3
Looks like air pressure in it. If you have a vacuum pump vacumm the system if not just purge it with the gauges
dallastxtech is offline   Reply With Quote
Anyone ever heard of a meter on the high voltage side? viper Electrical 9 05-20-2011 12:41 PM
Installing a water line for a side by side fridge mhp8982 Plumbing 43 09-20-2010 03:21 PM
High Efficiency Side Exhaust Vent TerrySki HVAC 8 04-06-2010 03:55 PM
Rheem Criterion 2: high fan heat only dyincolor HVAC 2 03-27-2010 10:17 PM
venting a high efficiency furnace through the roof (how high) allAboutDIY HVAC 11 10-21-2008 01:48 PM
