High Line Freezes - HVAC - DIY Chatroom Home Improvement Forum
Old 07-01-2012, 03:16 PM   #1
high line freezes
i installed a new compreessor in my rheem 3 ton heat pump it worked great for a day the n it quit cooling and the high pressure line is freezing up what is the problem
lasey-JANE is offline   Reply With Quote
Old 07-01-2012, 03:27 PM   #2
An old Tradesmen
Rewards Points: 6,140
Did you change out the filter drier.
Old 07-01-2012, 03:40 PM   #3
high line freexes
no i didnt
Old 07-01-2012, 04:28 PM   #4
An old Tradesmen
good chance thats where he problem is.
Old 07-01-2012, 06:26 PM   #5
high line freezes
how can i replace the drier without draining the freon can i isolate the freon
Old 07-01-2012, 06:27 PM   #6
JJboy's Avatar
pump down the refrigerant inside of the condenser
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-01-2012, 06:27 PM   #7
An old Tradesmen
have to recover it if the drier is inside the cabinet.
Old 07-01-2012, 06:50 PM   #8
high line freezes
how do i pump freon into the condenser i am not sure
Old 07-01-2012, 07:11 PM   #9
JJboy's Avatar
close the high service valve until the low gauge shows 0 psig.....close the low service valve
After you replace the dryer filter you have to leak test with nitrogen at 150 psig and them vacuum until micro test hit 500 micron....
Old 07-01-2012, 08:47 PM   #10
An old Tradesmen
Do you have an EPA cert to handle/work with refrigerants?
Old 07-02-2012, 05:32 AM   #11
Where, exactly, is the high pressure line freezing up? Do you see this on the indoor coil, for example, or somewhere on the outdoor unit?
Note that if the drier is INSIDE the condenser cabinet, you can't pump the refrigerant into the condenser. You'll have to recover the refrigerant, replace the drier, and then recharge. As beenthere said, if you don't have an EPA card you should not be doing this.
scottmcd9999 is offline   Reply With Quote
Is the line presssure too high ? sh1633 HVAC 3 06-22-2012 07:45 PM
Old water supply line a_lost_shadow Plumbing 7 04-20-2012 12:12 AM
tapping water line for new line KarlJay Plumbing 5 07-28-2010 10:30 AM
Replacing damaged BX line in kitchen wall fishnyc22 Electrical 5 02-17-2009 01:40 PM
