High Limit Switch Question - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-10-2010, 12:41 PM   #16
pgh
Originally Posted by Artco View Post
Do you have carbon monoxide detectors in your house?
If not purchase one at HD or Lowes and install it ASAP.
If the system trips on the new limit you may have a bad heat exchanger
Check for blocked return air.
along with everything else all have suggested.
YOU CANNOT SMELL CARBON MONOXIDE
Got 2 CO monitors installed now. One on the 1st floor and one in the basement. Thanks!
pgh is offline   Reply With Quote
Old 12-10-2010, 12:45 PM   #17
Originally Posted by pgh View Post
I did this the other night. The furnace spec gives an allowable range of 40 to 70 degF and I cam within that range when I measured the intake temp compared to the air coming out of the registers.
Can't measure at registers. Have to drill a hole in the supply trunk.
You get an uneven temps at the registers.
hvaclover is offline   Reply With Quote
Old 12-10-2010, 01:07 PM   #18
pgh
I was wondering what the small holes were in the supply and return coming off the furnace! Thanks. And the hole is about 1 foot from the main bonnet.
Old 12-10-2010, 07:21 PM   #19
Hvac Pro
yuri's Avatar
Rewards Points: 1,102
Now we are gettin somewhere.
Geez, you almost might think we do this for a livin.
Old 12-10-2010, 09:46 PM   #20
pgh
yuri: I know you guys do, and I thank you. I meant no disrespect
Thank you all for helping me through a fairly stressful time an thanks most for helping me save a few bucks so I can feed my kids.
Old 12-10-2010, 10:28 PM   #21
30 year tech
hvac122's Avatar
I would stay away from the filterette filters. They are highly restrictive new and get worse as they load up. Most ductwork is already undersized and these filters can trip the limits by blocking to much air.
hvac122 is offline   Reply With Quote
Old 12-11-2010, 08:21 AM   #22
Hvac Pro
yuri's Avatar
The trouble with Yuri's internet humor is it can be mistaken/misread. I was glad it worked out and ironic that the test hole was "1 ft downstream from the bonnet" like he said.
Old 12-12-2010, 08:18 AM   #23
An old Tradesmen
Rewards Points: 6,088
Filter replaced. Using a Filtrete 1900.
Now we are getting somewhere. I did find that 2 of the 1st floor registers were totally closed, in the kitchen and by the front door. One register on the 2nd floor was totally closed too. That may have been the issue.
Along with filtrete filter.
TRANE 90 xe High Limit Error -still.... BruceDJames HVAC 1 11-06-2010 04:48 PM
Touch sensitive switch question mothra Electrical 0 01-26-2010 02:17 PM
comfortmaker - 4 blink error - "open high limit switch" ericro HVAC 17 01-19-2009 10:36 AM
Wiring limit control on gas boiler uncleneiler Electrical 1 11-21-2008 09:03 AM
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 12:05 PM
