High Limit Switch - HVAC - DIY Chatroom Home Improvement Forum
Old 06-14-2009, 10:27 PM   #1
high limit switch
I have a brand new carrier three ton heat pump the the led light is telling me that is tripping out on the high pressure switch. What are some of the causes I could check out.
tarheelhvac is offline   Reply With Quote
Old 06-14-2009, 11:06 PM   #2
Make sure the outdoor fan if running properly. Make sure the outside unit is unobstructed on all sides and top so it has good airflow through the unit. Other than that you will need technician to check the charge.
SKIP4661 is offline   Reply With Quote
Old 06-14-2009, 11:13 PM   #3
So if the fan is running properly and it is unobstructed on all sides and top, the chances are it is over charged?
Old 06-15-2009, 07:20 AM   #4
You could simply have a bad switch. You could check ohms on the switch, but without know the specs on that switch its hard to know what it should be.
If this is a brand new system, why not just call the installer back. For sure your parts are covered, and many contractors will cover labor for a period.
dac122 is offline   Reply With Quote
Old 06-15-2009, 06:52 PM   #5
Brand new? Don't touch anything or your contractor could void your warranty.
You did have it professionally installed, I hope, cause if not Carrier is likely to turn down a DIY parts return.
hvaclover is offline   Reply With Quote
Blower fan runs constantly epowerfan HVAC 65 12-06-2011 06:57 AM
Motion switch wired to two circuits Sibkuz Electrical 2 04-22-2009 07:31 PM
Wiring limit control on gas boiler uncleneiler Electrical 1 11-21-2008 08:03 AM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 05:06 PM
Comfortmaker RPJII - 4 flashes - open high limit switch nisad HVAC 7 12-08-2006 11:33 AM
