High Limit Switch - HVAC - DIY Chatroom Home Improvement Forum
Old 03-13-2014, 05:01 PM   #1
high limit switch
I have a Sterling TF-45 heater in my garage and I need the high limit switch but its discontinued... I know its a 2 prong, 5" long, and opens at 175 deg closes at 145 deg model number j11r04768. Can I use any switch with those same stats or am I ?
spaghettios is offline   Reply With Quote
Old 03-13-2014, 05:11 PM   #2
An old Tradesmen
Rewards Points: 6,510
As long as it meets those specs, and mounts in the same place, and brand will be okay to use.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
ben's plumbing (03-13-2014), spaghettios (03-13-2014)
Old 03-13-2014, 05:42 PM   #3
Rewards Points: 32
Ummmm....
It's very rare that a highlimit switch needs replacement. On those rare occasions, it's usually because the high limit switch wont close properly, and thus shuts the furnace off when it shouldn't.
May I ask why you've decided the switch should be replaced?
SeattlePioneer is offline   Reply With Quote
Old 03-13-2014, 05:48 PM   #4
Originally Posted by SeattlePioneer View Post
Ummmm....
I purchased the heater without it. The heater is from 96 but has never been used, the guy sold some parts off it and this is the last one. I cant even find a replacement so im not too sure what to do...
Old 03-13-2014, 05:52 PM   #5
Rewards Points: 582
picture of the location of the limit would help us also try to select a replacement for you ,,,ben sr
Old 03-13-2014, 06:04 PM   #6
Heres the pic, it goes in the hole right in the middle, hole is about an inch wide.
Old 03-13-2014, 06:18 PM   #7
Stock one looks like this
Old 03-14-2014, 05:44 AM   #8
An old Tradesmen
Try Grainger. They stock limits.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (03-14-2014)
Old 03-14-2014, 06:11 AM   #9
Rewards Points: 582
yep ww grainger, johnstone supply,and just about any other heating company..ben sr.....standard limit ...
Old 03-14-2014, 08:59 AM   #10
biggles's Avatar
check here for an idea of prices http://www.bestbuyheatingandaircondi.../fan&limit.htm
The Following User Says Thank You to biggles For This Useful Post:
Trane XE 80 High Temp Limit Switch BCS HVAC 15 11-20-2013 05:40 AM
Heat Strip Limit Switch Help firedawgsatx HVAC 6 07-20-2013 10:14 AM
Heil Gas Furnace Ultimate II - High Limit Switch Triggering Problem hiei5 HVAC 11 07-24-2011 01:23 PM
Could a failed condensor fan raise pressure/trip high pressure limit switch? (Rheem) hennyh HVAC 6 07-30-2009 03:04 PM
Comfortmaker RPJII - 4 flashes - open high limit switch nisad HVAC 7 12-08-2006 12:33 PM
