High Limit Switch - HVAC - DIY Chatroom Home Improvement Forum
Old 01-20-2013, 09:16 PM   #1
High limit switch
I have a concord 80 plus gas furnace. It is making a buzzing noise. and the red light is blinking four times indicating the high limit switch is on. Is there anything I can do to fix it myself?
chuckkailo is offline   Reply With Quote
Old 01-20-2013, 09:38 PM   #2
Sure can. Limits trip because the unit has gotten too hot due to lack of air flow. That could be from a dirty filter,a dirty evap coil, a bad capacitor on a blower motor, a bad motor or a bad control board not sending voltage to the motor.
Old 01-21-2013, 01:50 PM   #3
Or the limit itself could be bad. However the buzzing you're hearing may be the motor attempting to run, which would lead me to believe the problem would be the motor or the capacitor. Easiest way to check is to turn on the fan, carefully reach back and feel if the fan is vibrating and getting hot. You can attempt to spin the motor (again be careful), if it starts & runs normally after you kick start it, the capacitor is probably the cause.
The capacitor is also going to be the cheapest and easiest to replace, so if I was unsure I'd try that first. You can take the old one out & take it to a parts warehouse so they can match the one you need. (you have to have a specific microfarad rating for different motors) There are 2 wires going into it, you don't have to worry about switching them, so it's an easy fix.
JScotty is offline   Reply With Quote
Heil Gas Furnace Ultimate II - High Limit Switch Triggering Problem hiei5 HVAC 11 07-24-2011 12:23 PM
Could a failed condensor fan raise pressure/trip high pressure limit switch? (Rheem) hennyh HVAC 6 07-30-2009 02:04 PM
Wiring limit control on gas boiler uncleneiler Electrical 1 11-21-2008 08:03 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Comfortmaker RPJII - 4 flashes - open high limit switch nisad HVAC 7 12-08-2006 11:33 AM
