High Everything Need Some Thoughts - HVAC - DIY Chatroom Home Improvement Forum
Old 07-19-2012, 03:38 PM   #1
jkv
high everything need some thoughts
Hey guys I got a call air not working when I got there I have 40* superheat, 25* supcooling, td around 5* indoor coil and out clean as can be this is a older 22 system the guy had a compressor I put it in for him now I have 26* subcooling 40* superheat 11.9 amp. on compressor and td of 15* any thoughts what am I missing here hot summer and getting tired
jkv is offline   Reply With Quote
Old 07-19-2012, 05:38 PM   #2
Had one like that today that ended up being non-condensables on an old system that had not ran in years. Reclaimed,vacuum pumped to 500 microns and recharged with fresh 22 and everything turned out perfect. No idea when or how air got in there but it was taking up a bunch of room in the condensing coils.
The Following User Says Thank You to Marty S. For This Useful Post:
ben's plumbing (07-19-2012)
Old 07-19-2012, 05:43 PM   #3
An old Tradesmen
Rewards Points: 7,754
Restriction somewhere. Or bad powerhead on the TXV if it has one.
The Following User Says Thank You to beenthere For This Useful Post:
Old 07-20-2012, 04:47 AM   #4
jkv
No txv, thought of air I tried the same thing Marty but no change at all. I was thinking restriction but have no idea were it could be I was going to check the orifice but you cant get to it.
Old 07-20-2012, 06:46 AM   #5
HVAC Contractor
Rewards Points: 290
This a heat pump? If so, possibly troubles with the reversing valve - check temps and pressures (if possible) on both in and out pipes to determine if you have major differences.
Drier(s) clogged? I've had to replace driers within days of compressors changes, and in fact include that in my quotes now.
If not TXV, then you'll have to get to the metering device. Some of them have screens, and the screen might be clogged, or might have trash in the orifice.
scottmcd9999 is offline   Reply With Quote
Old 07-20-2012, 03:55 PM   #6
jkv
not a heat pump but I have not got a call back so mabe all is good, I should have known by now. The laddy that lives their is on oxy. so that always worrys me more, I know 2 ton system and 85* inside you will have high superheat but this one got me. and with the landlord having me put in a 25 year old compressor worried me also.
Old 07-21-2012, 12:06 AM   #7
agree
hvac5646 is offline   Reply With Quote
Old 07-21-2012, 06:33 AM   #8
Did I read that right? You installed a 25 year old used compressor supplied by the landlord? Lesson learned,don't do that.
Old 07-21-2012, 06:46 AM   #9
jkv
Well it was a trane lol!
High pressure operating Sdeclara HVAC 13 01-17-2012 02:44 PM
How high is too high for washer drain jcpiebald Plumbing 5 12-30-2011 07:42 PM
High rise Plumbing question roach_779 Off Topic 8 01-17-2011 08:36 PM
How high is too high in fence construction? Jim F Building & Construction 17 05-14-2010 06:38 PM
Old refrigerator = high power consumption? RammsteinNicCage Appliances 6 06-13-2008 10:50 PM
