High Efficiency Gas Furnaces - HVAC - DIY Chatroom Home Improvement Forum
Old 09-15-2011, 07:42 PM   #1
high efficiency gas furnaces
I an new to the this chatline scene.
I live in northern BC Canada and I am in the market for purchasing a new high eff.Gas Furnace.
I am looking for input from anyone who has any info on Trane,Lennox,Carrier,and Bryant natural gas furnaces.
Any problems you may have had with any of furnaces would be greatly appreciated.on - /warrantee/durability/costs.(at the present quote re CARRIER gas furnace 96 % variable speed = $5000.00 Canadian Funds installed replacement cost)
No info on Lennox,Bryant,or Trane
Any comments would be greatly appreciated.
Thanks ceadog@telus.net
Gassy Jack is offline   Reply With Quote
Old 09-15-2011, 09:13 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
I do know that you need a drain line for the furnace and sometimes those have frozen up while in use, causing headaches. It does not matter which brand, they'll all require drain lines if they are condensing furnaces.
These drains are in addition to your evaporator cooling condenseate drain lines.
You'll also be needing a fresh air intake to the furnace which requires the use of a 2" or 3" pvc pipe to be run from the furnace to the outside of your home.
Good luck.
Doc Holliday is offline   Reply With Quote
High efficiency washing machine odors dinosaur1 Appliances 0 05-27-2011 09:13 AM
Heat pump or high efficiency furnace moisheh HVAC 13 11-14-2010 11:59 AM
Trane Excecutive High Efficiency Furnace Help kashimama HVAC 2 09-01-2009 06:46 PM
High Efficiency Furnace Combustion and Exhaust pirateo HVAC 7 08-13-2009 10:58 AM
Has anyone updated to high efficiency gas furnace? orange HVAC 30 11-20-2008 08:49 AM
