High Efficiency Furnaces? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-17-2008, 11:13 PM   #1
High Efficiency furnaces?
Thinking of replacing our original 30+ year old furnace with a new high efficiency furnace. Every salesman knows everything and their product is the best. So far local co-workers have pointed me towards getting an Amana/Goodman. I feel thats the way I am leaning unless other opinions show different. I'm looking for some good feedback.
jetchaser is offline   Reply With Quote
Old 06-18-2008, 04:29 PM   #2
Another DIY Zombie
Rewards Points: 264
Just do the research and check other manufacturers, also are you installing yourself or having a contractor do it? You should have a heat loss calc done on your house to determine the proper size of the unit.
javan is offline   Reply With Quote
Old 06-18-2008, 09:37 PM   #3
I was planning on having a contractor do it. I was kinda scared by such a big job. Really I was hoping people to state what they have and if they like it or not. Trane, Lenox, Amana, there are so many out there!!!
Old 06-19-2008, 08:33 AM   #4
Another DIY Zombie
Rewards Points: 264
I know that I am in the same boat. I am looking at replacing my Oil burning furnace with a new gas fired model. However, I am looking a few different options:
1. Gas furnace replacing the oil furnace.
2. Gas boiler, indirect water (to replace existing gas water heater), air handler w/ HW coil.
The 2nd option is more expensive up front, but much more efficient in the long run. Currently, I have two small gas water heaters, and one old oil-fired furnace. #2 will reduce my ignition sources down to 1, and no OIL!!!!
New High Efficiency Furnace Problem Buster 567 HVAC 8 12-13-2010 09:36 PM
Has anyone updated to high efficiency gas furnace? orange HVAC 30 11-20-2008 09:49 AM
high efficiency gas furnace hammer6315 General DIY Discussions 2 06-18-2008 11:25 PM
New High Efficiency Gas Furnace & Hot Water Heater frank08226 HVAC 2 04-17-2008 01:06 PM
Heil High Efficiency 5000 boman47k HVAC 5 12-14-2007 02:05 PM
