High Efficiency Furnace Water Leak - HVAC - DIY Chatroom Home Improvement Forum
Old 03-20-2009, 09:17 PM   #1
Newbie Bill
Rewards Points: 520
High Efficiency furnace water leak
Hey gang,
We have a high efficiency furnace, installed 2 years ago. Well I am downstairs the other day and notice a water drip hanging on the outside of one of the exhaust pipes. So that tells me it is leaking the condensed water.
It looks to be leaking from the joint between the two 22 deg elbows.
Sorry for the glare on the first photo.
Can I fix this myself by
1) Applying some ABS glue to the small gap between the 22's - if so, can I use plain ABS glue.
2) Cut the pipe above and below the 22 elbows and install new pipe - if so, could I get this pipe and elbows at HD again, what kind of glue? And can I use a hacksaw to cut this?
Or should I bring in a professional.
High Efficiency furnace water leak-dsc01836.jpg   High Efficiency furnace water leak-dsc01837.jpg
drtbk4ever is offline   Reply With Quote
Old 03-20-2009, 09:37 PM   #2
HVAC / Plumbing
You need to repair it..( properly) If water is comming out so could the flue/ exhaust gas. You need to cut it out clean ,prime & glue with pvc glue.. Yes you should be able to purchase from HD
kenmac is offline   Reply With Quote
Old 03-20-2009, 09:40 PM   #3
GC/Master Plumber/Mech
Rewards Points: 560
You can cut it out and make up a new joint. I have not seen many systems where the pipe are so tight not to allow some movement so that you can install glue in couplings. If they are so tight you can use a fernco or a no-hub
Old 03-20-2009, 09:41 PM   #4
Yes, you can fix it yourself. Use your hack saw and cut above and below the 45's. You can pick those up at any hardware store. buy some PVC glue, PVC cleaner and a short piece of pipe. The cleaner is very important, especially on the exhaust. Have fun
sgthvac is offline   Reply With Quote
Old 03-20-2009, 09:43 PM   #5
Newbie Bill
Rewards Points: 520
Wow thanks for the quick responses.
Yeah, my first thought was about flue gases in the house.
Do I have to be worried about shavings from the hacksaw falling into the furnace?
Old 03-20-2009, 09:50 PM   #6
Rewards Points: 560
With this being on the exhaust and with such a small amount then no.
Just be careful when cutting and if some large pieces come loose and fall you will have to remove them. Otherwise the inducer motor will blow out the small shavings
Old 03-20-2009, 09:56 PM   #7
HVAC / Plumbing
Don't know why the installer made that connection so close.. Is the PVC sch. 40 ?? If not it needs to be
Old 03-20-2009, 09:59 PM   #8
Rewards Points: 560
Just asking your area requires Sch40. Here they allow celcore?
Where are you located Kenm
Old 03-20-2009, 10:07 PM   #9
Hvac Pro
yuri's Avatar
Rewards Points: 1,412
In Canada only Schedule 40 is allowed. All new installs need the higher 636 grade now. http://www.ipexinc.com/Content/en_ca..._System636.asp
You can use regular for your repair but I would be forced to use 636 to meet the code.
Old 03-20-2009, 11:10 PM   #10
Newbie Bill
Rewards Points: 520
The whole install was a cluster &uck so I am not surprised by this.
Thanks for all the help guys.
Old 03-21-2009, 12:17 AM   #11
HVAC / Plumbing
I'am in Alabama....If you can show the inspector where the installation instructions approve the use of any other material you are ok..if not sch 40 must be used......you also have to use a purple primer on the joints ( this goes for plumbing also)..Of course I have seen them vented with D.W. vent... Must have been a hacker
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Water softener leak - how do I set it to bypass? Cylanth Plumbing 4 07-21-2010 10:24 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Water Leak Detection AppleMac*Fit Plumbing 16 12-29-2008 07:30 AM
