High Efficiency Furnace Venting - HVAC - DIY Chatroom Home Improvement Forum
Old 09-21-2012, 10:36 AM   #1
high efficiency furnace venting
I am just wondering if I can or should use the CPVC that Home Depot sells to vent (and supply combstion air) to my new furnace or listen to my wholesale guy. I forgot the name of the pipe he is trying to sell. They are both the same price practically but H.D. is handier. Thnx for your help.
Dave Purych is offline   Reply With Quote
Old 09-21-2012, 11:53 AM   #2
REP
The answer is no.I don't know the exact reason but I have never seen CPVC reccomended for venting purposes by the manufacturer.There must be a reason.My guess is that the heat and acid in the exhaust will cause the CPVC to get brittle and crack.
REP is offline   Reply With Quote
Old 09-22-2012, 09:06 AM   #3
An old Tradesmen
Rewards Points: 6,498
PVC or ABS is fine.
CPVC ID size is not the same as PVC. So you would need to use 2.5" CPVC when 2" PVC is what is called for.
Old 09-22-2012, 01:55 PM   #4
I don't know where you're located, but in Canada it has to be S636 PVC venting. If you can and do use ABS, don't use cellular core.
hvac benny is offline   Reply With Quote
The Following User Says Thank You to hvac benny For This Useful Post:
ben's plumbing (09-22-2012)
Old 09-22-2012, 03:40 PM   #5
An old Tradesmen
I'm in the states. I think the poster may be in Canada, so thanks for that info.
Old 09-22-2012, 10:11 PM   #6
Rewards Points: 582
no use pvc or abs....
Carrier furnace short cycling between Low and High heat drtbk4ever HVAC 16 01-15-2012 09:38 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Fumes from High Efficiency Gas Furnace Sandra L HVAC 8 11-14-2010 02:36 PM
High Efficiency furnace water leak drtbk4ever HVAC 10 03-21-2009 12:17 AM
Has anyone updated to high efficiency gas furnace? orange HVAC 30 11-20-2008 09:49 AM
