High Efficiency Furnace Venting - HVAC - DIY Chatroom Home Improvement Forum
Old 09-24-2011, 01:59 PM   #1
high efficiency furnace venting
I have a high efficiency furnace. At the end of the PVC pipe where it is vented outside, should there be some sort of insect or small rodent barrier, like chicken wire or screening? FYI, When it is freezing out, there is a build up of ice at the end. Thanks. -Steve-
steve2251 is offline   Reply With Quote
Old 09-24-2011, 02:41 PM   #2
Rewards Points: 6,652
Mine does not have anything over it.
Old 09-24-2011, 03:12 PM   #3
An old Tradesmen
Rewards Points: 6,464
If you put a screen in or over it. It will freeze shut and leave you without heat.
Old 09-24-2011, 03:33 PM   #4
fabrk8r
fabrk8r's Avatar
A discussion on the same subject from last year...
High Efficiency Furnace Exhaust Vent-Need Bird/Insect Screen
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Fumes from High Efficiency Gas Furnace Sandra L HVAC 8 11-14-2010 02:36 PM
High Efficiency furnace water leak drtbk4ever HVAC 10 03-21-2009 12:17 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
Has anyone updated to high efficiency gas furnace? orange HVAC 30 11-20-2008 09:49 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
