High Efficiency Furnace Combustion And Exhaust - HVAC - DIY Chatroom Home Improvement Forum
Old 08-12-2009, 03:05 PM   #1
High Efficiency Furnace Combustion and Exhaust
My new 95+ efficiency furnace had new pvc flues for combustion and exhaust added that now go out on the side of the house. The outlet is the same height as my fresh air intake and about 3 feet to the left.
Is there any risk having the fresh air intake and this outlet from the furnace so close?
pirateo is offline   Reply With Quote
Old 08-12-2009, 05:08 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,818
3 feet is fine with the code. You need to keep the snow away so the fumes don't swirl back to the intake and watch it on a cold day for recirculation.
Old 08-12-2009, 06:03 PM   #3
Thanks!
Old 08-13-2009, 07:16 AM   #4
Not to worry, I've seen them closer and still within the manufacturers install guidelines. Just follow yuri's advice if you live where you get cold and snow as it is not unusal for the intake or exhaust to ice up causing a blockage. Blockages cause a safety lock-out condition where the unit will not fire. If the PVC pipes don't have some large screening on them I would add it as kids and insects are the sworn enemies of those pipes promising to plug them.
dac122 is offline   Reply With Quote
Old 08-13-2009, 08:55 AM   #5
30 year tech
hvac122's Avatar
If your in a cold area don't put screen on them as this will freeze up and cause lockouts.
hvac122 is offline   Reply With Quote
Old 08-13-2009, 10:03 AM   #6
I was actually wondering about putting a screen over it. I've found a few bugs my blower compartment that came from the pvc.
Would it be okay to have the screen over it in the warm months and then take it off in the winter?
Old 08-13-2009, 10:48 AM   #7
30 year tech
hvac122's Avatar
It would be fine when the unit is not in use.
Old 08-13-2009, 10:58 AM   #8
Thanks!
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Carrier Furnace help code 31 fauxjaux HVAC 6 04-22-2010 10:36 PM
Payback going from 80% Furnace to 90%+ TheOak HVAC 37 12-02-2008 06:38 AM
Has anyone updated to high efficiency gas furnace? orange HVAC 30 11-20-2008 08:49 AM
Venting high eff. gas furnace through the wall. Prince1 HVAC 17 10-21-2008 11:12 PM
