Hiding Those Ugly Condensers..problem Solved - HVAC - DIY Chatroom Home Improvement Forum
Old 07-02-2012, 11:24 AM   #1
biggles's Avatar
hiding those ugly condensers..problem solved
just saw this on DIY "I Want That" and it can serve 2 purposes.besides looking like a bush in place and hopfully it doesn't starve or restrict the condensers air it looks good.the 2nd advantage you could run a copper line around the sides at the top nd feed water so the water trickles down the inlets and precools the inlet air on real hot days.the trade off of using water and saving WATTS on that bill is minimal...just needs to roll down and catch on the branches...as it evaps off the air going in will keep the unit working easier.if you want to get detailed install a 115V water solinoid and wire it into the T side of the compressor contact..so when the stat calls for cooling the water starts to trickle..definilty have a ball valve on the feeder line to adjust the water.water won't touch the condenser so no need for rot worry.......
Old 07-02-2012, 11:31 AM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Screams high head pressure, extremely hard to service and 100x's uglier than a condenser.
I'd charge an extra $50 if I had to deal with that thing. If I had to clean the condenser which that things again screams dirt trap, another $100.00.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
plummen (07-04-2012)
Old 07-02-2012, 06:59 PM   #3
You'll make a lot better than that Doc when the condensor fan motor dies and the compressor gets beat to death from lack of air flow.
Old 07-02-2012, 07:30 PM   #4
Rewards Points: 338
sheesh, what's next? the condenser bedazzler, condensers available in a variety of colors including hot pink? anything that reduces airflow in and around a condenser is a stupid idea.
NitroNate is offline   Reply With Quote
Old 07-04-2012, 10:19 AM   #5
Yes! Yes! Yes!
Mosiac with glass, even.
Oops, the part of my brain that Daddy taught was asleep for a minute there. Sorry.
Block the air flow(???) was my first thought when I saw that segment. Might be good for hiding trash cans, though.
Polly003 is offline   Reply With Quote
Old 07-04-2012, 11:50 PM   #6
Rewards Points: 616
kidding me right.......
carmon is offline   Reply With Quote
Old 07-05-2012, 05:19 PM   #7
Rewards Points: 156
There is ONE mechanical advantage to this thing, and that is it keeps direct sunlight off of the condenser. During the summer, I get evening sun on my condenser, and makes the system less efficient. With this, the hot sunlight can be kept off of it, and reduce the head pressures.
av-geek is offline   Reply With Quote
Old 07-05-2012, 07:26 PM   #8
An old Tradesmen
Rewards Points: 6,476
The amount of solar heat your condenser gets, its so little it make no noticeable difference. the amount your house is getting, is a different story.
Old 07-05-2012, 07:31 PM   #9
biggles's Avatar
leave the top off for no discharge retriction,and trickling water down the sides has to pre cool the inlet air on those real hot days
Goodman Heatpump problem solved! Rollie HVAC 4 12-14-2010 07:52 PM
Neutral problem, not sure what to do now BataviaJim Electrical 37 01-03-2009 12:00 PM
Electrical "arcing" problem? morden5b Electrical 17 12-17-2008 07:10 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
