Hey Pros: Did My YJ Gauge Manometer Fail Me? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-10-2009, 07:58 AM   #16
Originally Posted by hvaclover View Post
Might as well start a fire with flint and a rock...
Or cook a lamb with flame rollout
Old 04-10-2009, 09:09 AM   #17
lol
hvaclover is offline   Reply With Quote
Old 04-11-2009, 11:47 AM   #18
JohnH1's Avatar
My quick guess would be that someone drilled out the orfices on the burners. Manifold pressure is manifold pressure. The only way to increase gas at the normal manifold psi is to have larger orfices. This explains also why it works better at 1.75wc.
JohnH1 is offline   Reply With Quote
Old 04-11-2009, 04:40 PM   #19
Found my problem thanks to Isometric and a few other guys to whom I give credit.
i bench tested the valve and found the pilot and main valve opening simultaneously on an intermittent basis.
Now i been doing this stuff for 35 and I have never seen this happen before
on a redundant spark or HSI valve.
But the Smart Valve is controlled by what can pas for a mini micro prcesser.
The damn thing did a "Hal" on me (the computer that turned on the crew in 2001 A Space Odyssey) and almost killed me too.
I'm keeping his one for a souvenir.
Old 04-11-2009, 05:45 PM   #20
HVAC / Plumbing
Found my problem thanks to Isometric and a few other guy to whom I give credit.
Thing about this bus.. Always learning something..you & a few others were leaning toward the dumb valve . But just couldn't put a finger on the exact problem.. Probably cause they nor myself has never had / seen this problem .. I have never liked the honeywell smart valve..Sad thing is, they seem to be going bask to this for some reason.. I'll take HSI or direct spark ign . any day.. Thanks for sharing this info
kenmac is offline   Reply With Quote
Old 04-11-2009, 06:22 PM   #21
Thanks for taking time to post
10 gauge vs 12 gauge wire for 30 amp line hsdude1992 Electrical 10 08-19-2015 01:43 PM
Standard gauge for household electrical wire tripower Electrical 2 09-21-2008 11:42 PM
12 gauge wire to 14 gauge on an outlet question diyer4162 Electrical 35 12-20-2007 12:55 PM
14 gauge wires all over but no 15 amp breakers amakarevic Electrical 4 05-16-2007 08:47 AM
