Here Is Tip To Service A Furnace. - HVAC - DIY Chatroom Home Improvement Forum
Old 12-27-2009, 08:51 AM   #1
HVAC Tech/ Browns Fan
Here is tip to service a furnace.
Here is some tips to service furnace to save money.
Clean flame sensor or thermocouple ( replace it every 3 years)
Clean burners Note: use shop vac. do not take burners out you may not get them back in right
Oil all moving parts that Fan motor and draft motor.
90 % or higher and hum.Put white vinegar into drain to help clean out all the junk in it.
Clean fan blower dust and pet hair around the motor will in time causing to over heat. Check temp to on it. If it is runnig hot you may have trouble.
Check all wires and connections. Most of all check ground wires to insure good ground.
Change air filter and battery in thermostats.
That is what you can do to help the furnace to run good this year but it is still good to have the pro's to come out once awhile.
Tator1076 is offline   Reply With Quote
Furnace Service handy man88 HVAC 10 01-30-2009 06:32 PM
Furnace service manuals tondar HVAC 11 01-26-2009 07:51 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 10:31 AM
