Old 07-30-2011, 10:20 AM   #1
Here are the numbers...Good or Bad?
I live in Downriver MI. As some of you know, I'm looking to present my daughter with some basic HVAC tools when she completes school. I had a friend of mine who has an SMAN3 gauge. I asked (begged) him to come over and check my 20+ year old system. It's an Energy Knight (2 ton) with a Uni-pac air handler. 1,400 sq. ft. house. Before he came over I replaced the air filter, cleaned the evap. and cond. coils with Frost King coil cleaner.
The system was, and still is, cooling fine. After he checked the system over and noted tempature readings both "Wet bulb" (idle and running) and "Dry bulb" he hooked up the SMAN3 to the unit. With the system idle (not running) the low side pressure was 126.6 PSI and the hight side was 127..0 PSI Indoor tempature was 77 at the thermostat and 72 outdoor with a digital.
After running the system for 30 minutes, these were the readings:
Low side pressure 62.8
Low side pipe temp 62.7
High side pressure 227.7
High side temp 76.0
IDWB 65.9 (between the filter and evap.)
ODDB 75 (at the cond.)
Tempature at inside discharge 52.2
When I asked him what all these numbers mean, he playfuly said "go to school" I assume he didn't find anything out of wack with the system.
What do these numbers indicate to you guys? Do I need to provide any additional information. I was writing a lot of stuff down.
D
StahlMaster is offline   Reply With Quote
Old 07-30-2011, 12:30 PM   #2
JJboy's Avatar
High side temp 76.0
D
Target Superheat: 21
Actual Superheat: 25
Target Subcooling: 21
Actual Subcooling: 34
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-30-2011, 02:17 PM   #3
An old Tradesmen
That air handler should have a TXV. And if it does, something isn't quiet right. probably either a slightly restricted LLFD, or the TXV isn't opening all the way.
Again its not off by much, just a bit. SH is high for a 20 year old HV system.
If he had measured the leaving wetbulb and the CFM, I could tell you the capacity it was operating at, during that check.
Old 07-30-2011, 09:15 PM   #4
This unit does not have a LLFD installed. Not on the line outside or in the cabinet. I'm guessing the TXV is the issue. Is there a way to get it to open all the way without removing it?
D
Old 07-30-2011, 09:47 PM   #5
An old Tradesmen
Not really. Not if its the problem.
Old 07-30-2011, 10:07 PM   #6
JJboy's Avatar
You can replace the power head first.
Old 07-30-2011, 10:20 PM   #7
FYI,
If both the TWXand LLFD check out A-OK, the put a jumper across the SRTV and check the SH/SC PRV to assess the WWDM. The SCWSMMYR or the SSCCVTTVS can sometimes mimic a faulty SSDR, leading of course to SHET
Anti-wingnut is offline   Reply With Quote
Old 07-30-2011, 10:30 PM   #8
JJboy's Avatar
Originally Posted by Anti-wingnut View Post
FYI,
I SSXXDY KNDO FFFde DDXF****IID
Old 07-30-2011, 10:34 PM   #9
Exactly
Old 07-30-2011, 11:28 PM   #10
I'd give it a shot. Where is the valve information located? where can I get a replacement?
Old 07-31-2011, 12:52 AM   #11
I like the numbers the way they are. If the unit is cooling the house well, I would leave it alone. If anything you may have a slight overcharge in my opinion, but it wouldn't be much. The head pressure is slightly over the typical 30 degrees above ambient corresponding pressure that you would expect,(but it's close) and the subcooling is a little high, that's why I would suggest that. The temp drop is acceptable considering you are at nearly 70% RH at the conditions specified. At that RH a good percentage of your capacity is going into latent heat removal in the form of condensate. I would predict as the house drys out a bit that the temp drop accross the coil will increase as well. My guess is it may not have a TXV at all, but is using a piston of some sort or a cap tube.
HVACDave is offline   Reply With Quote
Old 07-31-2011, 06:20 AM   #12
An old Tradesmen
If he has his EPA cert.
Old 07-31-2011, 09:36 AM   #13
I don't have a EPA certificate but my friend who was here does. Once the weather cools down a bit, I'm sure he'll come over to get this old system working at it's peak efficacy. I need to buy some time before replacing the unit.
D
AC not cooling, but numbers look good wetbar HVAC 15 07-13-2011 09:14 PM
Mount House Numbers in Brick sderam45 Building & Construction 12 05-11-2011 12:44 PM
Can't find good laminate comparison anywhere cpsilo1 Flooring 3 03-20-2011 05:49 PM
Where can I find good contractor and building material suppliers? denniis Off Topic 5 03-10-2009 10:27 AM
Looks like a good Christmas this year! leroyme Off Topic 6 12-23-2007 11:45 AM
