Hercules Base Hit II V Hercules Boiler Fluid - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-03-2010, 07:03 PM   #16
An old Tradesmen
Rewards Points: 7,318
Get 2 short pieces of all thread. Remove existing ties.
Put in smaller all thread rods, and tighten nuts so the back and middle section are held together.
Old 09-04-2010, 10:52 AM   #17
Not too sure if this is possible because the middle section just has a recess or curve for the tie rods to pass through from front section to the back section.....what do you think (re diagram)
All the best,
Martin
Invisible-Man is offline   Reply With Quote
Old 09-04-2010, 01:01 PM   #18
An old Tradesmen
Should have enough room to get a washer and nut on to hold it while you move it around.
haven't had one of them apart for awhile.
Old 09-04-2010, 01:21 PM   #19
I understand now.......if I think the leak is between the front and middle section then this would be a way of saving the other join........
I may well purchase 2 of the sealing kits anyway, can always keep one as a spare!
I do appreciate all your help and perhaps will let you know how I get on in October during my visit to Michigan........
Thanks again......
All the best,
Martin
Oversized boiler solution (radiant heat)? gbwillner HVAC 5 02-14-2010 06:28 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
How to create a curved wooden base shoe? hayzen Carpentry 3 07-28-2009 03:29 PM
Boiler size Bonnie Youngs HVAC 29 07-10-2009 07:58 PM
Boiler w. Hydronic Air & Honeywell Aquastat DanA28 HVAC 1 01-08-2009 04:21 PM
