We recently bought this house and apparently at one time it had dual zones (there is a thermostat upstairs and one downstairs). Upon checking in the attic it looks as if one damper motor is hooked up and the other one was disconnected for some unknown reason. I hooked up the other one (assuming I connected it correctly with the wires) but have not noticed any difference in air output in either zone.
The labels on the dampers say it is "California economizer" size 24x12. From what I understand this is/was a division of Zonex. There is also a piece sticking out from the duct-work labeled Synchron. I am assuming this is the damper motor?
I would love to get this working but unsure where to start. Would I assume correctly that the motor is probably burnt out? Is it easy and relatively inexpensive to replace?
thank you for any help you can provide!
