Help For York Evaporator Coil Clean Up -FG8B05012MU11A - HVAC - DIY Chatroom Home Improvement Forum
Old 06-28-2013, 05:19 PM   #1
Help for York Evaporator Coil Clean up -FG8B05012MU11A
Will you guys please help me in telling me which panel / area I should remove to see the evaporator coil
Mounted horizontally in attic. In take from right side of picture(facing) and exit from left side.
Modelno:FG8B05012MU11A
jacob1234 is offline   Reply With Quote
Old 06-28-2013, 05:53 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 396
1) follow the Freon lines from outside to where they attach to the coil inside
2) airflow is from right to left <<<< so it should be on the left side. not a good idea to put them B4 the fan on the right air incoming side and is illegal where I am. OK with electric furnaces but not recommended.
Old 06-28-2013, 06:39 PM   #3
Thank you Yuri
I i cannot figure out .I will post another picture late in the evening
Old 06-28-2013, 08:07 PM   #4
An old Tradesmen
Rewards Points: 8,184
The coil should be to the left of that furnace.
Old 06-29-2013, 12:13 AM   #5
Thank you beenthere
I am including couple more pictures. The original problem was an open start capacitor(blower for eva coil). You can see that I opened blower compartment.
I just want to take a look at the eva coil before I close everything with new capacitor
Can any one tell me which side of coil section I should open.The duct on the top is coming from the second unit
PICTURES ARE UPSIDE DOWN
Old 06-29-2013, 05:34 AM   #6
An old Tradesmen
The coil is where those 2 copper lines run into that box on the furnace.
Old 06-29-2013, 07:48 AM   #7
Rewards Points: 242
it doesn't look like there is an access panel. they used an uncased coil?
hvac instructor is offline   Reply With Quote
Old 06-29-2013, 07:58 AM   #8
Hvac Pro
yuri's Avatar
Rewards Points: 396
U need 2 cut your own access panel behind where the smokepipe/venting for the furnace comes out and that shiny big flex duct attaches.
Old 07-09-2013, 09:53 AM   #9
Thank you evey one .There were screws hiding behind the foil tape on top side I removed them,slide the cover off and cleaned the coil
Again thanks for the tip
Tags
fg8b05012mu11a
Clean out vs floor drain zubor Plumbing 2 10-25-2012 08:19 PM
Best way to clean up metal cap with build up dirt? Andee77 Painting 1 07-27-2012 09:19 PM
Looking for ideas...drywalling a clean out MLayden Drywall & Plaster 1 06-15-2012 11:14 AM
How to clean porcelan tiles? Talking Dreams Tiling, ceramics, marble 4 02-08-2009 09:01 AM
Creating a clean, sharp caulk line? JDuc Painting 5 01-18-2008 08:14 AM
