Help Wiring Squirrel Cage Fan - HVAC - DIY Chatroom Home Improvement Forum
Old 07-13-2011, 06:12 PM   #1
Help wiring squirrel cage fan
I have a blower I salvaged from our old furnace that I'd like to use as ventilation in the garage but I'm not sure where to start.
The motor is a GE EDIT: 5SME39HL 0240 (HD44RE120 must be the Bryant model), marked 120/240v (I'm guessing/hoping it's set up for 120 but I have no idea how to tell or change it) single phase. I don't have the capacitor it came with -- but I'm also not sure if it had one.
There are 2 wiring harnesses plugged in to it as follows:
First:
1: Black
2: White
3: Green/yellow
And pins 4-5 are jumpered
Second:
1: Yellow
2: Red
3: Blue
4: Green
If someone could at least give me a clue as to where to start I would be forever grateful. I think I've gathered that red and blue are for speed control, but would I wire that to hot, neutral or ground?
Edit: Now that I had the right model # I did find the document below. The pins aren't the same but it does give me a little to work with. I tried wiring white and black on the first harness to hot and neutral, grounding green and grounding red from the second harness. No go.
http://gpsinformation.info/joe/carrier/GE_ECM_data.txt
qoncept is offline   Reply With Quote
Old 07-13-2011, 06:55 PM   #2
JJboy's Avatar
First:
1: Black - L1 - 120V
2: White -L2 - 120V
3: Green/yellow - Ground
And pins 4-5 are jumpered - I think is rotation
Second:
1: Yellow - Speed - not use
2: Red - Speed - not use
3: Blue - Speed - Not use
4: Green - Ground
Where is the brown wires for the capacitor?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-14-2011, 08:22 AM   #3
That's it for wires, there are no brown. According to that document I linked those last 2 pins are jumpered to run @110, open for 220. I hope that's right. I'll try your way out tonight. Thanks!
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Blower squirrel cage Dbenzboy HVAC 4 08-27-2010 08:05 PM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
Squirrel cage motor in air handler...no start andyinrichmond HVAC 13 03-15-2009 03:53 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
