Help Wiring Programmable Thermostat
Thanks for your help. I finally managed to figure it out by shining a flashlight on the circuit board of the old thermostat. The letters were there next to the terminals in a faint green colour, similar to the circuit board (very hard to see in the dark corner where the thermostat is located).
Turned out that the red wire was RH and the black was W. I labelled them before disconnecting it, as per the instructions. Got the new one hooked up and programmed and it's working fine.
The thing I like about this Uberhaus Design one is that it's portable. You can actually remove the touchscreen thermostat from the wall plate to program it, which works well considering its awkward location in my townhouse. It's a difficult place to stand and adjust the settings because I have a heavy piece of furniture beneath it. This way, I can just pull it off the wall and sit on the sofa with it, then put it back on the wall when I have it programmed right.
