Help Wiring My Furnace Blower Motor - HVAC - DIY Chatroom Home Improvement Forum
Old 12-23-2010, 09:13 PM   #1
help wiring my furnace blower motor
i have a dayton model # 6k376 and all the wiring diagrams don't match up with my furnace. i only have a black, white and green wires coming from my furnace. how do i wire this?
jmorton is offline   Reply With Quote
Old 12-23-2010, 09:33 PM   #2
HVAC / Plumbing
Just single speed motor. Green is ground. Black is line 1 or hot when power is sent for motor to come on. white is netural
kenmac is offline   Reply With Quote
Old 12-24-2010, 07:11 AM   #3
help wiring furnace blower motor
but where do i hook them on the motor. there is a terminal with a white black and yellow wire connected to it with one open terminal (to plug another wire in). there is a terminal with an orange and black, a terminal with a red wire, one with a yellow wire and open terminal, and one terminal with two open spots. the diagram says nothing about the white and green wires. they are all connected by 1/4in connectors. i would do trial and error but i'm worried that i would fry the motor.
Old 12-24-2010, 05:13 PM   #4
Retired Electrician
did you look on the inside of the cover there should be a diagram for the connections can you post a pic of the termal block, it allso should say which wires to change rotation
fy171 is offline   Reply With Quote
Old 12-24-2010, 05:37 PM   #5
Retired Electrician
does it have the motor info on the side
Old 12-24-2010, 06:34 PM   #6
biggles's Avatar
look at the schematic on the side of the motor your going for a 115V hookup.forget the green wire it mounts to the green screw inside the terminal section opening...the 2 black wires on the terminals are the capacitor connections..look close in with a flashlight they have to be numbered and correspond to the schematic....just watch that direction CW/CCW which is a wire change within there if wrong on start...if you don't have that taped on schematic don't guess but with 115V you won't burn the motor out..just wont have action.your description of a terminal with 2 open spots whats that 2 slip connecters??
Old 12-24-2010, 08:32 PM   #7
Belt drive....yoy need to look at the wiring diagram on the label or connection dust plate.
hvaclover is offline   Reply With Quote
Old 12-25-2010, 01:33 AM   #8
Houston204's Avatar
Rewards Points: 556
Is this a MagicAire air handler?
I've installed this motor many times. There are diagrams on the motor describing voltage configurations. Strangely, it usually comes configured for 115VAC.
Power connects to the 2 spade terminals with 11/32" nuts.
The green wire connects to the 1/4" hex green screw.
Houston204 is offline   Reply With Quote
Old 12-25-2010, 02:54 AM   #9
The diagram will show L1 and L2.
Black goes to L1 white goes to L2.
ICP Furnace Blower Motor SheeB HVAC 8 04-17-2011 12:42 PM
Furnace Shuts down B4 Blower motor engages Kooks from Michigan HVAC 5 03-18-2011 12:11 PM
Another blower thread...Please help!!! keqwow HVAC 2 11-01-2010 04:50 AM
Questions about finding replacement blower motor revg HVAC 3 02-14-2010 07:39 PM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 09:09 PM
