Old 08-28-2011, 08:42 PM   #1
Help will AC cooling
OK here is brain buster.
AC will cool the house with no issues when its set at 74 degrees. If i change it to 75 or higher it will not cool (it will be 80+ degrees in the house).
I replaced the thermostat this weekend and same issue. I really don't want another 600 bill. Has anyone had or seen this issue before.
nbk9fmr is offline   Reply With Quote
Old 08-28-2011, 09:45 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
If it cools to 74 or lower, then there is not a problem.
Old 08-28-2011, 09:47 PM   #3
ha ha other than a 400 elec bill. It was set at 76 degrees forever
Old 08-28-2011, 09:48 PM   #4
I want to set the thermostat back to 76 and it would be 76 in the house not 80 degrees
Old 08-28-2011, 10:03 PM   #5
An old Tradesmen
When you set it to 74, does it shut off, or does it run 24/7?
Old 08-28-2011, 10:12 PM   #6
It runs 24/7
Old 08-28-2011, 10:15 PM   #7
An old Tradesmen
Your compressor is probably running too hot, and when you set it to 75 an d it shuts off, the compressor's internal thermal over load opens. And takes probably close tom 3 hours to cool down and close again.
Try cleaning the condense coil.
Old 08-28-2011, 10:18 PM   #8
Ok makes little sense but why if I set it to 75 it never gets cold but on 74 its freezing
Old 08-28-2011, 10:22 PM   #9
An old Tradesmen
Cause when you set it to 74, the condenser never shuts off. But at 75 it shuts off, and then doesn't restart after it shuts off for another 3 hours.
Yes, I'm making a wild guess. But its based on what little info you can/have provided.
I like it 72. At 72 my A/C has long run times. At 73 it doesn't feel very cool.
Old 08-28-2011, 10:24 PM   #10
Ok I got it now I will try that thanks so much for the info
Old 08-28-2011, 10:49 PM   #11
I'm Your Huckleberry
You might want to have a tech come out and check that charge.
Doc Holliday is offline   Reply With Quote
Old 09-01-2011, 07:55 AM   #12
Update
I washed out the coils and alot of dirty flushed out. So far so good set the ac back to 75 and its been running well. Keeping my fingers crossed
Thanks for the help
Cooling capacity relation with air temperature. Samart HVAC 2 06-23-2011 08:39 PM
Help! Just changed my Fan Controler (ICM 275) now system "false starts" when cooling redmachodevil HVAC 4 01-26-2011 04:21 AM
lennox g20 whisper heat cooling mood cargom HVAC 0 09-25-2010 10:41 PM
Wiring a Ruud RGTK-06E series furnace for 2-ton cooling bolo_invictus HVAC 3 01-25-2010 04:24 PM
Installation of Honeywell Thermostat - cooling function KDW Electrical 0 10-04-2009 10:56 AM
