Help - What Kind Of Thermostat? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-04-2009, 11:04 AM   #1
New owner, older house
help - what kind of thermostat?
We have a 4 ton package unit (not split) AC with gas heat. Currently it has an old thermostat that is not quite accurate--we'd like to upgrade to a digital thermostat. Is there a specific type that needs to be installed since we have gas heat? Is there one brand that is better than another?
Any help is appreciated--thanks in advance
Taz38 is offline   Reply With Quote
Old 01-04-2009, 11:25 AM   #2
Rewards Points: 502
Does your current system have a heat pump with backup gas heat? Or is it just gas heat and A/C?
If the later, then you should be fine with a single stage thermostat.
If the first (HP and gas heat) you'll want a two stage t-stat with an outdoor thermostat on the HP.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 01-04-2009, 11:25 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,452
Honeywell Vision Pro (touch screen) or Focus Pro are 2 of the best. You need to see if there is a W2 wire terminal on the one you have for 2 stage htg. If it has that then buy a 2 stage thermostat only. Post the make and model and serial # of the unit and we may be able to look up a wiring diagram for it.
Old 01-04-2009, 11:32 AM   #4
biggles's Avatar
check out the Grainger site www.grainger.com item# 4TL92 Honeywell digital stat will give you a basic idea for that package.W is the typical heat contol point from that unit.so you will be looking at R,G,Y1,W1,C to connect down into any style of digital stat for gas fired rooftops.you will configure the stat thru sub menus for gas,electric,oil heat/cooling stages and 25 other non-application items values they offer.check the grainger prices and hit Lowes and HD for comprable styles and brands.basically most are systems...heat/off/auto/cool fan...on/auto then setting as wake/leave/return/sleep for temps and times.Honeywell has the Vision Pro series also,and that can be wired to your unit also which is like an ATM screen with no buttons or switches. http://www.hotfreshcool.com/visionpro_demo.html
Old 01-04-2009, 12:10 PM   #5
thanks so much--we stood in the t-stat aisle and were a little overwhelmed. I knew you guys could help!
I'll have to get the unit's information later--we're not working at the house today.
Help move baseboard heater thermostat and avoid electrocution Gunserotti Electrical 28 01-04-2009 05:48 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 04:57 PM
