Help With A Venmar Supra Control - HVAC - DIY Chatroom Home Improvement Forum
Old 01-20-2009, 02:03 PM   #1
dgbehrends's Avatar
Rewards Points: 150
Send a message via Yahoo to dgbehrends
Help with a Venmar supra control
Hi and thanks for reading,
Does anyone have knowledge of how the 4 wires going to a Venmar supra control work? The supra control has 4 terminals, Y, R, G, and B. It has 3 settings plus a dehumidistat. 20on/40off (low speed), Constant on low speed, and Constant on high speed.
D in MN
dgbehrends is offline   Reply With Quote
Old 01-21-2009, 01:47 PM   #2
dgbehrends's Avatar
Rewards Points: 150
Follow up
I called Venmar today and here is what they said.
The unit uses 24V low voltage signals
Bk is the hot
G is the high switch
R is the low switch
Y is the common
The supra control has a timer that toggles the High setting on every 20 minutes out of the hour.
There is also an Override switch for bath timers and etc...
Bk (OC) is the hot terminal
R is high setting
Y is for the LED
The override terminals can be used in conjunction with supra control and will take precedence over it at the HRV.
This can be seen on page 20 of the install manual from venmar's website. My unit is the HE 2.6.
D in MN
Grundfos Circulator with Vaiable Speed Control amatantsev HVAC 3 01-23-2010 12:52 PM
Ventelation control recomendation dgbehrends HVAC 24 04-09-2009 03:13 PM
SEWER BACK UP, Which Flood Control Good????? diyjt5259 Plumbing 1 10-08-2008 10:44 AM
