Help Troubleshooting Furnace Problem - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-13-2009, 10:12 PM   #16
Gee, wonder why they did that.
Giving you the benefit of the doubt. It's the control board...most likely
hvaclover is offline   Reply With Quote
Old 02-13-2009, 10:20 PM   #17
Originally Posted by hvaclover View Post
I rest my case,troll.
The moderator closed the thread so I wouldn't attempt a DIY repair, and you have no clue. If you have a point, please sharpen it.
robert_ is offline   Reply With Quote
Old 02-13-2009, 10:22 PM   #18
Old 02-13-2009, 10:51 PM   #19
Is the thing I outlined the control board? If so, is it something that a service person needs to swap, or is it just a matter of changing the wires from the old one to the new one?
Old 02-14-2012, 10:19 PM   #20
new topic
I have an American standard freedom90 single stage furnace my board went on the blink,on the back of the board,you could see were it burnt out.So i replaced it with a intergraded white rogers board.That worked out well except the burners only came on for 2 minuted then went out.I noticed a burnt smell coming out of the registers at this time, also the diagnostic code flashed 4 times.This tells me in my manual there is an open limit device open.So i had my reset limit switch under my burner box replaced it has a reset on it,i also replaced another limit which is screwed into the furnace i believe to sense the temperature. After doing all this i restarted the furnace, it ran for 5 minutes,then shut off again and the diagnostic code flashed again 4 times. im confused does anyone have any suggestions as to what avenue i should do next. Thankyou
Rokochy is offline   Reply With Quote
Old 02-14-2012, 10:59 PM   #21
These threads might be helpful,
Trane Open High Limit Device
http://www.doityourself.com/forum/ga...ont-reset.html
You will need to look for these switches on your particular type of board. Hopefully this helps!
frankie3s is offline   Reply With Quote
Old 02-15-2012, 08:04 AM   #22
Please start a new thread.
You question will then be answered. But in the mean time kill the furnace power.
hvac5646 is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Help with furnace blower problem Spydey HVAC 6 12-15-2010 08:18 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Strange Problem with My Furnace chenjijc HVAC 14 11-04-2009 09:05 PM
