HELP! Trane XV90 Solid Red & Green Light - HVAC - DIY Chatroom Home Improvement Forum
Old 10-27-2011, 01:03 PM   #1
My Trane XV90 stopped turning on this morn. The circuit board is showing a solid red and solid green light. There is a green light also in the bottom right corner that is flashing rapidly, barely visible. The 5 amp fuse on the board is okay. There is no water around or inside the unit. There is no smell of burning wires or anything that looks loose. I've cycled the power off for a minute but that didn't help. I can hear the relays switching in my electronic honeywell thermostat but the furnace blower doesn't turn on.
Local HVAC said it is probably a bad circuit board. Wants $700, installed if it turns out that is the case. OUCH. Hoping maybe there is another fix I've overlooked?
Any suggestions are greatly appreciated.
consultant is offline   Reply With Quote
Old 10-27-2011, 04:00 PM   #2
An old Tradesmen
Rewards Points: 7,816
Count the flashes, and look on the legend for what error code it is.
What colors go good with a light green? tina21 Interior Decorating 20 12-30-2015 04:58 AM
Adding 2 more lights to existing light BCH_COLIN Electrical 7 01-24-2011 11:04 AM
Pilot light -trane xe78 skippy47 HVAC 5 03-02-2010 04:34 PM
Trane XL 80 won't light. cdcamaro9534 HVAC 4 02-16-2010 05:06 PM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 07:11 PM
