Help With Trane Xb-13 Not Cooling - HVAC - DIY Chatroom Home Improvement Forum
Old 07-18-2013, 06:57 PM   #1
help with trane xb-13 not cooling
I came home today and noticed my second floor was 92 degrees. A/C was set at 78 when I left the house this am. Tried resetting thermostat, no difference. Looked outside and the heat pump for the second floor was not working. Breakers were not tripped but I reset them anyway. Pulled panel off outside unit and no reset button...has a small condenser? but does not look bulged...a little round on top. There was a green blinking light on circuit board. Tried everything and fan on heat pump will not work. Line going into house is not sweaty or cold. The A/C unit is in the attic. It's a hundred degrees today in Virginia and will be this way for the next 4 days. Any suggestions?
whyedearp is offline   Reply With Quote
Old 07-18-2013, 07:37 PM   #2
rounded top on a capacitor would be a bad one
Old 07-18-2013, 07:40 PM   #3
biggles's Avatar
reset the breaker to reset the 24v locked out condenser
Old 07-18-2013, 07:59 PM   #4
I will replace the capacitor tomorrow. I don't hear the compressor or motor humming? I have now turned the upstairs a/c off but it might be too late? Do you think the motor or compressor is bad, since I don't hear a humming?
Old 07-18-2013, 08:00 PM   #5
Not sure what you mean by resetting the breaker to the 24v capacitor?
Trane XE 1000 not cooling masbirdies HVAC 5 02-27-2013 12:08 AM
Trane XE 90 coupled W/XE1000 A/C No cooling gmbwrenchn HVAC 6 05-28-2012 05:26 PM
Trane XR90 - Condensate Drane Trap JDWorks HVAC 16 02-07-2012 08:59 PM
Trane HP aux heat comes when cooling satisfied not_hvac_tech HVAC 7 07-25-2011 04:58 PM
new install of Trane XL15i nind HVAC 32 01-30-2010 01:59 PM
