Help With Trane Furnace - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-10-2011, 03:43 PM   #16
Experienced
Jackofall1's Avatar
Did you try and run the furnace with the combustion blower sensing tubes disconnected?
Mark
Old 02-11-2011, 09:28 AM   #17
troubleshooting
My suggestion would be to start from the beginning with your troubleshooting.
1. Is the fuse connected to the low voltage side or the high voltage side of your transformer or mounted on a control board? (if low voltage move to #2)(if high voltage check to make sure your door switch isn't moving when you put the doors back on and shorting to the case)
2. disconnect the wires from the gas valve and put tape over the wire ends.
3. put your panels on and start the furnace.
4 it should go through the start-up to the point where the gas valve would energize and stop there.
5 If your fuse still blows then you have a short between the fuse and gas valve, ie limit switch.
college A/C is offline   Reply With Quote
Tags
fuse blowing , heat , short circuit , trane
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Honeywell stat wiring w/ Trane furnace JaePee HVAC 7 01-18-2009 06:50 AM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
