#1 |
Help with t-stat 2h/1c
Hello. I have a Carrier Heat Pump System (electric, I think it is 2H/1C) that uses a Honeywell T874G thermostat with a Q674L subbase. My currernt thermostat has the following 7 wires:
1-W2 2-G 3-E 4-R 5-C 6-Y 7-O I am interested in upgrading to a wireless t-stat so I can control the temp from upstairs. The only problem is that there is no E terminal on the new t-stat. This is the manual for the receiver of the new t-stat http://www.xpedio.carrier.com/idc/gr...m-tstat-10.pdf It is a wireless carrier. http://www.residential.carrier.com/p...wireless.shtml Basically my question is what to do w/ the E wire from my system. Should I just tape it up and not use it? I have read some posts online that E is sometimes jumped to W2 but that doesn't make sense to me and they are separate terminals on my current t-stat. Please help. Thanks!! Also, it is possible that the new t-stat is not correct for my system? Last edited by intensol; 11-22-2008 at 06:00 PM. |
#2 |
An old Tradesmen
Your new stat probably doesn't require an E teminal because its internal circuitry uses W2 for the emergency heat, when switched to it.
#3 |
[quote=intensol;188684]Hello. I have a Carrier Heat Pump System (electric, I think it is 2H/1C) that uses a Honeywell T874G thermostat with a Q674L subbase. My currernt thermostat has the following 7 wires:
1-W2 2-G 3-E 4-R 5-C 6-Y 7-O __________________________________________________ _____________ W-1, is for your reversing valve. Some package system uses two wires to power the two sets of auxilliary heat. I set is used during defrost mode or temp is below 35F, and the other set is for emergency mode only. You can either connect this W2 and E wire together to W2 terminal of your replacement thermostat or leave the "E" disconnected and taped up. The only way to verify how this "E" wire is connected to your auxilliary heat system is to trace this wire all the way to your indoor unit (split system) or outdoor unit ( package system). Use the "6- wire, 1st stage cooling, 2nd stage heat" heat pump wiring instruction from the instruction manual. |
#4 |
Thanks for the info. My thought was that if I connected W2 and E together and that terminal went live that they would both go on even though I don't need emergency heat. I'm guessing it doesn't work that way?
I don't have access to the split system because one is in the attic and the other is on the roof of the condo so I can't determine where E runs to. Also, by what I described would you say that I have a 2H/1C heat pump system? The W2 is the 2nd heat cycle right? Thanks again. |
#5 | |
Help with t-stat 2h/1cQuote:
| Display Modes | |
| Is it actually cheaper to.......??????? | MrShadetree0222 | HVAC | 21 | 10-11-2008 12:11 PM |
| Problem with fan coil unit/hydronic system. | flood1911 | HVAC | 2 | 09-05-2008 05:57 PM |
| Help installing Honeywell RTH8500 | cloongoon | HVAC | 7 | 03-06-2008 09:52 PM |
| ritetemp programmable stat | miked18 | HVAC | 9 | 12-17-2007 07:20 PM |
