Help With Rheem Criterion Gas Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 11-08-2012, 10:32 AM   #1
Help with Rheem Criterion Gas Furnace
I live in New Orleans, and the cold weather season just about started so this is the first time running the heat for the winter this year...
My AC (cold air) works fine.
However, my heat works every now and then. Following things have happened in the last 7 days:
- Heater worked for a bit without any issues
- Then, i replaced the batteries since the battery low indicator was blinking
- Then, in ON position, the air was blowing but No Heat.
- Then, I pressed Reset and then the Heater worked once it was cranked up all the way to 80, but was not working when it was around 73
- Now, it's not working again regardless of which temperature I set it at
Bottom line is that it is working sporadically.
Any ideas on what's going on?
slwije is offline   Reply With Quote
Old 11-08-2012, 01:11 PM   #2
JJboy's Avatar
First step I'd bypass the Tstat by remove the cover and jumper R-W.
Sent from my iPhone using DIY Forum
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 11-08-2012, 01:54 PM   #3
Model numbers would help to know what type of heating system you have.
Old 11-08-2012, 01:57 PM   #4
Duh...gas heat. Sorry I missed that. Look for blinking lights in the furnace and achart on the door saying what they mean
Old 11-08-2012, 02:57 PM   #5
RGPH - 07 eauer
Old 11-08-2012, 03:03 PM   #6
I'm Your Huckleberry
Rewards Points: 2,270
I'd do what JJboy said first, bypass the stat. Jump r-w. Two ways to do this; remove the face of the stat to expose wire terminals or in the furnace at the control board.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 11-08-2012, 04:10 PM   #7
What is Jump r-w?...and how do I attempt this?
Old 11-09-2012, 10:02 AM   #8
UPDATE:
I've noticed for the last 3 days that the heater will work normally between the hours of 5 PM and 11 PM
However, does not work overnight to early morning.
AND NO my t-stat is not a programmable one.
Old 11-13-2012, 08:44 AM   #9
UPDATE:
I installed a new tstat. The cool air runs fine but the heat is definitely not working. Ay ideas?
Circuit Board for Rheem Criterion II Furnace jmkamk HVAC 2 01-16-2012 09:44 AM
rheem furnace failure sydefx101 HVAC 8 01-09-2012 06:29 AM
Rheem RGDG-075AUER gas furnace lights intermittently ge01734 HVAC 5 01-01-2012 06:40 PM
Problem with old Rheem furnace ignition Troublefix HVAC 7 02-02-2011 04:52 PM
Rheem RGFD Furnace Flashing 66 LED sneaky_pete HVAC 4 12-28-2007 06:31 AM
