Help Removing Carrier Blower - HVAC - DIY Chatroom Home Improvement Forum
Old 07-27-2008, 11:06 AM   #1
Help removing carrier blower
Hi,
I have a Carrier A/C (model 58RAV, downflow), its blower stopped working a few day's ago. When turning on, I can hear sound that the motor is attempting to start, but the blower never rotates. The capacitor and other electronics seem fine. So I decide to replace the blower.
I follow instruction in the mannual at http://www.docs.hvacpartners.com/idc...it/om58-94.pdf and http://www.xpedio.carrier.com/idc/gr...58p,r-12sm.pdf
At step 2, it says "disconnect short piece of vent pipe from relief box", but there is no chart or any detailed info on how to disconnect them. It seem almost impossible to disconnect them without a major work.
Can anyone please give some pictures or detailed info on how to disconnect them?
Many thanks
Frank
vicn12 is offline   Reply With Quote
Old 07-27-2008, 01:25 PM   #2
oops, did I do that!
Well you have a counterflow furnace and need to remove the vent pipe in order to get the blower out.
There should be at least 3, 1/4in sheet metal screws, in the pipe at the relief box. Unscrew them, and the ones in the first section of pipe where it comes out of the furnace. Pull the pipe apart, reassemble the same way.
8 Ball is offline   Reply With Quote
Old 09-29-2008, 08:50 PM   #3
outcome?
frank - just came across this post. what was the verdict on your unit? i have what sounds like the exact same problem. blower? capacitor? other? thanks for the info!
brando is offline   Reply With Quote
Carrier 58MVP Blower Problem mickd HVAC 57 04-11-2017 07:28 AM
Comfortmaker blower intermittent problem jh44ny HVAC 12 07-31-2011 06:41 PM
Carrier air handler blower part pwrengineer HVAC 8 04-16-2011 12:42 PM
Heat comes on but blower never does aczer HVAC 12 02-13-2011 06:57 AM
Carrier furnace blower adjustment?? psillypsymun HVAC 1 10-26-2007 06:19 PM
