Help Please ! Heat Pump Tstat Wiring Issues Maybe? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-04-2010, 11:10 AM   #16
An old Tradesmen
Rewards Points: 8,168
Post brand and model number of all of your equipment. So we know what you really have.
Old 12-04-2010, 12:38 PM   #17
ok so.... what is is listed below...
but when it was wired up it would run the heat pump em heat and cooling b4...... but maybe that is why it keep killing everything (not i also notcied that the stat wires out side when i replaced where passed do to be replaced bare wires and such so i replaced all the cables even on the one on the emheat temp thingy...
model # ----make
n8msn091714a------heil gas unit
44860------- hunter thermostat
brhq030b---- coleman evcon heat pump
but if you look at my post with all the info about wires the colors really dont make any sence.
House--- Unit Wire/term---- EmHeat RElay box on side
RED---- RED /R
BLUE---- BLACK /C--------- (BLACK EMHEAT WIRE)
ORANGE ---ORANGE /O
GREEN ----GRAY /L--------- ( RED EMHEAT RELAY WIRE)
YELLOW ---YELLOW /Y
WHITE ---- STRIGHT TO EMHEAT RELAY----(WHITE EMHEAT RELAY WIRE)
BROWN---- WHITE /W2------- ( GREEN EMHEAT RELAY WIRE)
i think when it was wired the green was on the board to gas unit. and when the system sent a call to the "L" system i think is when it is killing my stuff... but i am not really sure i know it worked all 3 units when it was wired
madmat276 is offline   Reply With Quote
Old 12-04-2010, 12:58 PM   #18
AKA HVACTECHFW
Rewards Points: 1,208
in the instructions that you posted for your relay, it states that it is for use with electric back up, which you don't have!!! You need a dual fuel kit!!!
hvactech126 is offline   Reply With Quote
Rheem Package Heat Pump Newbie03 HVAC 4 02-26-2010 06:32 PM
Heat Pump Control Wiring Questions IBuiltPools HVAC 3 01-14-2010 01:45 PM
Wiring a Honeywell ProVision TH8321U1006, upgrade from Weathertron Tstat drandersoninc HVAC 6 10-04-2009 03:20 PM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 10:28 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
