Help Please - HVAC - DIY Chatroom Home Improvement Forum
Old 08-20-2010, 02:19 PM   #1
Help please
I guys i have a problem, our house is always dusty and so we are planing on putting in a AccuClean Whole Home Air Filtration System. Now the problem is that the new filter is 7.5'' wide and we had a 1'' filter before. The duct is 6'' away from the furnace. I will attach a picture to show for a better idea..
http://i953.photobucket.com/albums/a...TER/FILTER.jpg
http://i953.photobucket.com/albums/a...00820-1506.jpg
THANKS!
magapenguins is offline   Reply With Quote
Old 08-20-2010, 02:23 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,856
Mount it horizontally in the return air duct drop if the manufacturer allows that. Otherwise you need to get an extension piece/offset made by a tinsmith to allow it to be put where the existing filter is. Then move the spare filters and washer/dryer over a bit. DO NOT reduce the return duct size or the furnace and AC will suffer.
Old 08-20-2010, 02:33 PM   #3
Yea it allows for it to be mounted on its side but they don't make a unit in that size... As for moving the duct over a little bit it should work, how much more should it be to have a tinsmith to make that piece (about ish)?
Old 08-20-2010, 02:36 PM   #4
Hvac Pro
yuri's Avatar
Case of beer if you know the guy. Depends on your local contractors rates. I would expect under $200. You would need precise measurements to the 1/4" and good pics for them to make it. Need some S-clips to attach it with.
Old 08-20-2010, 02:40 PM   #5
lol yea that would be nice.. wow that is quite a bit, hopefully its abit less...the filter itself is around 800 whats anouther 100 or so
Old 08-20-2010, 02:42 PM   #6
Hvac Pro
yuri's Avatar
I really don't know your local costs. Most people don't do much for $100 these days and a sheet of metal costs over $25.
Old 08-20-2010, 02:46 PM   #7
yea true.. but with the way the economy is here someone just might be happy to get a few extra bucks. well thanks for answering so quick
Tags
furnace filter , help!
