Help With Older A/C Unit - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 05-24-2011, 01:10 PM   #31
Hvac Pro
yuri's Avatar
Rewards Points: 2,266
The resistance varies from different manufacturers, BTUs/Hp of the compressor etc etc so there is no definite readings. Usually 3-5 ohms from what I remember. If it is shorted make sure NO ONE gets near it or touches it when you reset it or they will be the path to ground and DEATH. Shorted/shorting compressors sometimes run the condensor fan slowly and confuse people and can electrocute you if you touch it.
Old 05-24-2011, 01:31 PM   #32
Rewards Points: 154
so there may be a glimmer of hope yet...3 ohms was my lowest...here's to hope.
I'll check the resistance to ground tomorrow morning pending the weather...check back around 11 - noon ish.
I have the fuse out so there's no power and I won't be plugging them in again until something has changed to maybe fix the problem or a new unit is installed.
Thanks.
pete0403 is offline   Reply With Quote
Old 05-24-2011, 04:04 PM   #33
Rewards Points: 1,216
Time to replace it locked rotor or grounded when the fuses blow that fast.
COLDIRON is offline   Reply With Quote
Old 05-24-2011, 05:30 PM   #34
Pete the compressor is shot if you're reading almost 1000 ohms, it should be under 5 ohms.
Old 05-24-2011, 06:34 PM   #35
Rewards Points: 154
Okay. Then I guess the next question would be, once we're ready to replace, do we just replace the condenser unit or the lines and evaporator as well?
The furnace is a mid-efficiency from 2002 but judging from the age of the humidifier I replaced when we moved in, I'd say the evaporator is as old as the condenser.
Old 05-24-2011, 08:05 PM   #36
Condesor and evap coil needs to be a matched set. Keeping the old evap coil will make your new 13 seer more like an 8 and reduce capacity. I'd replace the line set also
Old 05-24-2011, 08:31 PM   #37
Hvac Pro
yuri's Avatar
I agree. The old evap coil will leak freon VERY soon from age. Also will not match the new condensor and even if you tried it the operating pressures will be wrong and you will lose capacity and efficiency. I replace the lines 99% of the time. 1% is the people with totally enclosed ceilings. It gets pretty humid in Southern Ontario and with a newborn I would buy a new unit sooner than later. Trying to get one in the middle of Summer or a heatwave is going to cost a LOT more and you may have to wait/suffer for weeks by the time they get to you (Momma ain't going to be happy and you know where that leads to). Try Direct Energy or Ontario Hydro/Hydro One or whatever they call themselves. They may have rebates for higher efficiency units and reasonable financing plans. $6000 high end unit over 60 months is $100/month and you can get them cheaper than that.
Old 05-25-2011, 10:39 AM   #38
Rewards Points: 154
Okay, thanks everyone. Just for ****s and giggles I checked the compressor again.
None of the lines are any where near shorted to ground. But I got similar readings for resistance between the lines (3, 903, 906 ohms). So I guess the windings are separated/corroded inside but not touching ground.
Thanks again, this has been the most helpful set of forums I've ever been on!
Old 06-13-2011, 11:01 PM   #39
Rewards Points: 154
Just an update...We got a new AC installed...it took two days of 44*C humidex temperatures for us to get a line of credit and have my cousin who is a certified installer put one in for us. Now the weather is cold again
The Following User Says Thank You to pete0403 For This Useful Post:
Doc Holliday (06-13-2011)
Old 06-13-2011, 11:09 PM   #40
I'm Your Huckleberry
Rewards Points: 2,270
That's pretty funny.
Doc Holliday is offline   Reply With Quote
Old 06-14-2011, 11:12 PM   #41
Rewards Points: 154
Maybe from you point of view Doc. Did you get your rooftop unit on time?
Old 06-14-2011, 11:16 PM   #42
Six tons of 410-A Trane cooling/ heat pump installed today. Waiting on the electricians to give us power.
I enjoy working with cranes, always a blast.
Old 06-15-2011, 09:20 AM   #43
Rewards Points: 154
Trane is the brand I got installed as well. A little smaller though.
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 10:11 AM
Window A/C Unit and Supplying Power JayEnder Electrical 1 04-30-2011 07:50 PM
Novice with an older Ruud unit hardnoxU HVAC 1 11-17-2010 08:16 PM
Can I upgrade the compressor in my RV roof AC unit? eoptrab HVAC 10 09-02-2010 04:43 PM
Evaporator unit is out under the house randyloy HVAC 1 08-29-2010 05:33 PM
