Help With Old Lennox AC Unit 2.5ton - HVAC - DIY Chatroom Home Improvement Forum
Old 07-12-2009, 12:42 PM   #1
help with old lennox AC unit 2.5ton
Old lennox central AC system. The evap is a C5-495-1FF (if I read the tag right. the condenser is a HSW4 (or something like that) r22 2.5ton
the condenser is shot, wanted to install a new unused trane / american standard alligance 10 2ton unit we had sitting around our shop
the lennox looked like it did not use a TXV (of course) nor did it use an orifice tube ? we cant see and fitting on the evap coil to hold an orifice. It looks like they used a fixed length (50ft or so) capilary tube 1/4" which is very confusing. we installed the alligance unit a few days ago, upped the liquid line to 3/8" evacuated and tested the system filled with R22 and it seems to cool the house, but the pressure seems low 85psi low about 130psi high. I cant add an orifice tube (no fitting), could use the cappillary since it is still there, or install a TXV and have it done with. which would increase the SEER rating alot. any help apprecitaed
northcoastmech is offline   Reply With Quote
Old 07-12-2009, 12:48 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,296
It used a liquid line bored out to be a capillary tube and may not ever work properly. Here is a link to a TSB which may be more helpful:http://tech.lennoxintl.com/PDFs/8317.pdf
Can't get unit to turn on need electrical help please-wiring diagram included igotshocked Electrical 33 01-30-2014 05:13 AM
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 10:11 AM
Lennox A/C unit not starting netddd HVAC 8 08-16-2010 11:30 PM
central unit will not come on ....please help guyasc HVAC 5 08-24-2008 05:10 PM
Wall unit AC drips water inside fw2007 HVAC 4 08-15-2008 10:07 AM
