Old 01-28-2010, 11:15 PM   #1
HELP old apartment .. Return Duct / Heat pump
Need to know if my apartment is vented WRONG... (whether HVAC is my problem) I dont know a lot about HVAC.. so please bare with me and I'll try to answer any follow up questions....
Basically I live in an old apartment.. which has the typical A/C unit/heat pump/outside fan. The heat pump is in an outside storage which is on the side of my apartment building (not like a shed, but actually a side room which is a part of the main building). It is completely isolated from my apartment (other than the return duct)... and has its own door to the outside. I have a return air duct which goes through the wall of my apartment into this storage shed... but that return duct does not run all the way back into the heat pump. It just dumps out in the storage area.... about 5-feet away from the intake on the heat pump... This storage area is not insulated... not sealed and has a ton of places air can easily seep in..
thethrowdown is offline   Reply With Quote
Old 01-29-2010, 04:36 PM   #2
got any pictures?
ricky82g is offline   Reply With Quote
VisionPRO Setup Functions & Heat Pump infoskr HVAC 31 03-18-2010 02:15 PM
heat pump / BTU question jwalker95 HVAC 3 12-07-2009 07:40 AM
Water Source Heat Pump installation JLMitchell HVAC 6 11-30-2009 04:23 AM
Ductless Heat Pump for Garage?? brittlediabetic HVAC 25 04-23-2009 03:28 PM
question on return duct familyman HVAC 13 01-25-2009 12:05 PM
