Help! No Heat And Its Cold!!! - HVAC - DIY Chatroom Home Improvement Forum
Old 01-21-2011, 10:12 PM   #1
Help! No heat and its cold!!!
19 year old Ruud system. Smelled something burning. Outside unit not turning, inside exchange not running but low buzzing sound. Replaced fan motor but no change. ideas?
XPSDONNY28 is offline   Reply With Quote
Old 01-22-2011, 05:15 AM   #2
An old Tradesmen
Rewards Points: 7,826
Need to use a meter and see what is and is not getting power. And then repair or replace that item.
Old 01-22-2011, 07:41 AM   #3
After smelling a strong burning odor, wouldnt there be some visual evidence of something that had burned up? Capacitor on motor looks clean and no other component is charred. Odor was stronger in upstairs bedrooms. Similar event happened three years ago and the motor was replaced, which led me to believe the same this time.
Old 01-22-2011, 07:45 AM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 178
Do you have a heat pump outside and electric strip heaters in the indoor unit. If so one of the elements may be burning up and its wiring.
Old 01-22-2011, 07:59 AM   #5
Yes, thats the set up i have. Strips are located just above the fan housing. But if thats the culprit, wouldnt the fan still run? With ac and heat on "off" I switched t-stat from "auto" to "fan" and get nothing but a low buzzing sound from inside unit.
Old 01-22-2011, 08:07 AM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 178
No. There are several sequencers and relays for the fan and elements which can be faulty and HIGH voltage there which can kill you. Best to call a tech who works on electric furnaces/air handlers with heat strips to find out. I have seen electric furnaces catch on fire and the wiring in a 19 yr old unit is brittle and prone to overheating so you need a Pro ASAP.
Old 01-22-2011, 09:09 PM   #7
An old Tradesmen
Thursday. I changed out a blower wheel and motor. The customer said they had smoke coming out of the ducts. The motor was toasted inside, but its housing looked fine, no marks on it.
