Help! No Air Coming From Master Bedroom Vent!!! - HVAC - DIY Chatroom Home Improvement Forum
Old 05-29-2007, 01:21 AM   #1
Angry
Help! no air coming from master bedroom vent!!!
I need your expertise to solve this problem bothering me so much!
My 2 story house is 4 years old and no air coming out from master bedroom vent! It makes my sleep miserable...
I tried to check if anything got stuck in the duct but it is hard to see.
Is there anything I can try to find out?
Thanks for your time.
thomasmona is offline   Reply With Quote
Old 05-29-2007, 01:31 AM   #2
Did it use to work and then stop, or has it never worked since you bought it?....Is it the only vent that isn't working? Is there attic access,...If there is access you can crawl up there and see if the ducting is disconnected somewhere.
send_it_all is offline   Reply With Quote
Old 05-29-2007, 09:53 AM   #3
just to make sure that ZERO air is flowing though (as opposed to very weak flow).
I would say try to get to the duct work (in the attic hopefully). The problem might be very obvious if you can see the duct.
It does matter whether there are problems in the rest of the home too.
Is there not a HVAC section here?
"Good judgment comes from experience. Experience comes from bad judgment."
keyser soze is offline   Reply With Quote
Old 06-02-2007, 09:56 PM   #4
when you are in the attic it will be easy to trace the duct from the bedroom back to the main trunk,check to see if a difuser is in the line,there may be a knob or lever of some type that has been turned to reduce the air flow.
blade is offline   Reply With Quote
Master Bedroom Remodel zel Project Showcase 10 01-29-2008 06:19 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 06:34 PM
enlargeing or adding on to bedroom rev1953 Building & Construction 1 05-20-2007 08:13 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 09:57 AM
Turning a Guest Bedroom into a Master Bath BbAaSsSs Remodeling 18 03-10-2007 05:03 PM
