Help With New Duct Work Trunk Running To Attic From Basement. - HVAC - DIY Chatroom Home Improvement Forum
Old 10-01-2011, 04:17 PM   #1
Work Hard, Play Harder
Rewards Points: 212
Help with new duct work trunk running to attic from basement.
Last winter when we purchased our home we had new duct work installed throughout the home (see other posts for reasons...)
The new duct work runs from the basement up to the attack and then branches out to the 2nd floor rooms that way. This new "trunk" was run using up two closets. The work did not include carpentry in the estimate; so the duct work is there and there are big holes in the floor/ceiling of the closets going up to the attack. This joins the attic, first floor, second floor and basement air zones to each other.
What is the proper way to seal this off? I don't want to frame around it if that isn't the correct choice; but air can easily travel from the attic to the basement (etc). I would like to close this off first in the basement ceiling; and then in the attic floor.
Advice? Suggestions?
(Edit: grammar, etc).
coderguy is offline   Reply With Quote
Old 10-01-2011, 06:59 PM   #2
DIY staff
Rewards Points: 7,174
Add fire blocking (wood ) where ever you can and then seal the gaps using fire stop foam---
No gaps that will allow fire or air to spread from floor to floor.
coderguy (10-02-2011)
Old 10-01-2011, 07:08 PM   #3
Rewards Points: 150
I had an inspector tell me this summer that fire stop caulking was not an approved fire stopping method anymore. It still boggles me every time I see it in the supply house.
OhioHomeDoctor is offline   Reply With Quote
Old 10-01-2011, 07:15 PM   #4
DIY staff
Have you got a citation on that?
Old 10-01-2011, 07:59 PM   #5
Rewards Points: 212
I can put the wood right up against the duct? I was thinking wrap the duck with the metalic backed insulation; put the wood almost up to that and then fill with the fireblocking foam?
Old 10-01-2011, 10:00 PM   #6
DIY staff
I think that's fine--one of the HVAC pros will know or Gary--be patient---Mike---
Old 10-02-2011, 04:37 AM   #7
An old Tradesmen
Rewards Points: 7,332
Foil faced insulation and then fire caulking it is ok. Then you can chase it after that if you want.
The Following User Says Thank You to beenthere For This Useful Post:
Old 10-02-2011, 09:49 AM   #8
Rewards Points: 212
I don't understand what you mean by chase it?
Old 10-02-2011, 10:22 AM   #9
Frame it in
Master of Cold is offline   Reply With Quote
The Following User Says Thank You to Master of Cold For This Useful Post:
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
How far down will basement duct work drop my ceiling? ctote HVAC 1 07-17-2011 08:57 PM
routing wires...attic or basement? redline9k Electrical 2 03-07-2011 01:43 PM
Ranting about attic work IvoryRing Electrical 6 04-16-2008 07:21 AM
Running Romex up from basement to attic tra999 Electrical 1 07-25-2006 04:21 AM
