Help Needed ... Turn On Circulation Pump When Furnace In AC Mode? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-03-2009, 11:56 AM   #1
Help Needed ... turn on circulation pump when furnace in AC mode?
Short version: I have a pump that simply plugs in to an outlet and is on non-stop. It draws ~120w. I need it to only be on when the furnace is on, and in 'AC' mode. How can I make this happen?
Long version: We've recently finished building our home in the SF Bay Area (temperate climate) and rather than build a full AC system in (which is fairly uncommon around here), we ran two copper coils into the ground and have created a "poor mans" ground loop cooling system. We've got a water-to-air radiator in the outlet of the furnace before it runs into the ducts, and a pump that pumps the water in a loop throughout the system. Obviously we only want the pump running when the furnace is in AC mode...
(Don't ask how well it works yet ... we just finished plumbing it last night and honestly its not hot enough around here to do any good right now...)
Diranged is offline   Reply With Quote
Old 06-03-2009, 12:06 PM   #2
http://electronicaircleaners.com/s688a1007.aspx
This works with airflow so you'd need to pull plugs or throw switches twice/yr when changing from A/C to heating and vice versa.
If you want it fully automated post a photo of the schematic of your HVAC unit. Probably one additional relay is all that is needed.
Old 06-03-2009, 12:13 PM   #3
I'll post a photo this afternoon... I'm looking for fully automated if possible. I'm using a Goodman 95% AFUE two stage multi-speed furnace, but I've been unable to find the manual for it online all day.
Old 06-03-2009, 12:29 PM   #4
The schematic is probably pasted on the inside of the one of the removable furnace panels.
Making and testing a small logic circuit that does this function requires that you can follow a simple schematic and do soldering, and you may need to borrow a DVM for testing.
It might take you a morning. Parts can be had from Radio Shack or Hosfelt.com. Probably $10 would cover it, with shipping extra.
If the pump is supposed to run when the compressor runs this should be very simple to implement; a step-down 'former to power a relay with Normally Open contacts, or just a 24vac relay that is controlled by your t'stat.
The relay contacts need to be be able to switch a 1A motor load.
Old 06-03-2009, 12:44 PM   #5
If the pump is supposed to run when the compressor runs this should be very simple to implement; a step-down 'former and a relay, or just a 24vac relay [the relay having contacts that can switch a 1A motor load].
Correct me if I'm wrong... should there be a power source from the furnace (one wire, or two?) that sends a small signal voltage (24v?) to signal a standard AC unit to turn on?
If thats the case, I need to have something that can read that voltage and flip a relay that then powers the pump... this is the part I'm not sure how to do though.
Old 06-03-2009, 12:55 PM   #6
Yes, and your added relay [~$2] should have a coil impedance high enough that the t'stat doesn't notice the extra current draw.
If you can get numbers and symbols off the compressor relay we will know it's coil resistance and so we can choose an appropriate add-on relay. This info might be on your HVAC parts list.
Otherwise we just pick off 120v from the compressor cooling fan or 240v from the compressor and step it down with a 'former [~$3] to power almost any relay. You could even use a doorbell 'former and we pick the relay coil voltage to match.
This is the kind of circuit that works on the first try.
Old 06-03-2009, 01:24 PM   #7
I spoke to one of the EE's at my office and he suggested that a simple relay should do the trick... if I get a 24VAC input relay and hook it up to the Cooling (+) and Common wire from the thermostat then it should be able to switch a 110V load. Though way overkill, we found a few on DigiKey. I'm wondering if I might find such a part @ Home Depot or Radio Shack?
(We cuoldnt find any 24v stuff on radioshack.com... not sure if they might have it in-store though...)
Does that seem right? Could it be that simple?
Old 06-03-2009, 01:39 PM   #8
Here's the wiring diagram for my furnace...
http://www.goodmanmfg.com/Portals/0/pdf/SS/SS-GMH95.pdf
Page 13
(too big to attach to this thread)
Old 06-03-2009, 02:23 PM   #9
The Y and C terminals probably supply 24vac when cooling is selected.
http://www.hvacmechanic.com/tstatwiring.htm
With 40VA 'formers you have 1.7A available, some portion of which is used the existing equipment. Let's say all we want to draw is 1.7/10 = 170 mA for the relay coil.
Hosfelt 45-640 has a coil resistance (or impedance?) of 160 ohms, so it would draw 24/160 = 150 mA or less. Sounds like that would work; otherwise you could look at All Electronics or Digi-key or Mouser or Jameco for a higher impedance coil. Some of their websites are a bear to search, so you might want to call.
You know, some guy back in the 70s did this and he got pretty good cooling. He used a car radiator from a junk yard. HVAC people came by to look at it because they didn't believe it.
While I have your attention, could I get from you your house sq. footage including basement and your heating gas/oil therms for, let's say, last December? I'm doing statistics on heat loss and I'm short about 20 datapoints.
Here's that stuff for my old house. Your new, low infiltration, well-insulated, house should do much better.
My house, 838 therms of NG in 90 days = 9.3 therms/day
3100 sq. ft. including basement gives 9.3/3100 = 300 BTU/sq.ft.
2658 HDD/90 = 30 HDD in one day
300/30 = 10 BTU/day/sq.ft./HDD
Multiply by 0.8 to allow for efficiency of gas/oil = 8 BTU/sq. ft./HDD
Say hi to your EE friend. I don't recommend it as a career field!
Old 06-03-2009, 06:00 PM   #10
biggles's Avatar
simple catch the C off the TR then Y for cooling within the furnace,then the NO contacts for the black wire for the pump.this is an enclosed relay you pop a knock out on the side of the furnace and the wires end up inside the control section http://bestbuyheatingandaircondition...Code=r-general
Old 06-03-2009, 06:50 PM   #11
I got it working! Thanks for everyones help... here's what I did:
I bought a Dayton 5x823 relay (SPDT -- I didn't really need double throw, but thats all that was in stock) and a 2DW02 mounting base. I bought some tiny (thermostat sized) 2-wire cabling as well as an extension cord and ran the 2-wire into a box. The extension cord went into the box, and right back out of it.
The 2-wires hooked up to the C and the Y1 terminals of the Thermostat/Furnace (my furnace does have a Y1 connector, and it was wired up) -- and the other ends were wired up in the box to the relay coil ports. (2 and 6, i think)
The Inside the box I split open the extension cord and cut the Black wire. I plugged the "hot" end into port 1, and the other black wire ("cold" i guess) into the switched port (7, I think).
It works great... turns on whenever the "AC" is called for by the thermostat, and shuts off when its not in use. Its all wrapped up in a nice PVC box with proper ends on everything so that its clear how it works in the future.
Thanks again!
Yoyizit,
in reference to your #'s ... I don't have them handy right now, but I can try to get them and post them here. Our december bill was pretty rough, but we were seeing a staggering number of days below freezing here in the bay area that month...
Old 06-03-2009, 07:14 PM   #12
December 1st -> 31st:
70.2 Therms used in 30 days = 2.34 therms/day
2700 sq. ft
(two floors, first floor slab foundation, all R19 and R30 insulation)
(two furnace systems, 75k BTU downstairs, 45K BTU upstairs)
furnaces are both 95% AFUE NG furnaces with electric fans
Old 06-04-2009, 06:33 AM   #13
2700 sq. ft
Thanks; I get 540 HDD for that period at your location which gives you 4.7 BTU/sq. ft./HDD
.....x......x.xx.x....x.x
0...........................10
Your heat loss looks to be about average.
Comfortmaker furnace won't turn on steelframe8459 HVAC 36 11-30-2011 03:22 PM
Heat Pump will not turn on beakon20 HVAC 5 08-22-2008 02:53 PM
Just to confirm, no GFCI needed for hard wired pool pump..right?? Al the Diy guy Electrical 6 02-10-2008 12:28 PM
Help Please, Furnace won't turn on lh0628 HVAC 8 10-09-2007 03:07 PM
no heat when turn furnace on atl HVAC 1 10-24-2006 12:38 PM
