Help!!! Need My A/C Back - HVAC - DIY Chatroom Home Improvement Forum
Old 06-25-2009, 03:47 PM   #1
Help!!! Need my A/C back
Hi Guys,
I am hoping someone can help me here. Here is my issue..
Here is what I have:
We started our Central air. It was barely blowing any cold air out at all. Furnace fan motor was running. I had a tech guy come out to our house. After testing the freon levels and the degree chnage he said everything was ok on that end
I explained to him that this past winter (which was very cold) we had trouble keeping the house warm. The furnace would run and run and barely keep the house warm. A few times the motor would shut down as the plenum was red hot. then as it cooled it would speed up ands engage again. It kept recycling like this.
When I told the tech guy this story he said it sounds like my Fan motor is not getting up to speed?
That is what might be causing my central air unit to not blow cold air as well. Not enough air passing by the coils. But if my motor is running how is it broke??
Not knowing who to believe..does this sound logical? or do you have any other suggestions?
I apprecaite any input you can give me .
Thank you
Scott
Scott43 is offline   Reply With Quote
Old 06-25-2009, 03:55 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Do you know what the pressures were and outside temp?
Sounds to me that the evap coil is plugged and needs cleaned.
When was the last time you changed the filter?
Old 06-25-2009, 03:56 PM   #3
30 year tech
hvac122's Avatar
Sounds logical. It could also be a bad capaciter or dirty coil to name a few other things.
So did he check the motor or what. Should have checked the amperage and the bearings. If the bearings are bad it could very well run for awhile then overheat.
hvac122 is offline   Reply With Quote
Old 06-25-2009, 04:12 PM   #4
He said the pressures were ok. I do not have the exact reading. He said the temperature difference was 18 degrees??
The hammock filter gets changed 6 times a year.
Old 06-25-2009, 04:26 PM   #5
I am going to get an amp meter and check the motor myself.
Also check the bad capaciter as well.
foam back siding vs. reg vinyl siding marnic Building & Construction 3 02-16-2009 07:48 AM
mitre saw kick back rcm572 Tools 2 02-04-2009 07:46 AM
Heat Pump set back GEAF HVAC 6 01-26-2009 07:49 AM
Trends in 2009: POPCORN TEXTURE IS BACK! studiobarb Interior Decorating 11 09-02-2008 06:26 PM
Sloping Floor and back half of the house. Help! mikeinfrisco Building & Construction 1 01-22-2005 08:50 AM
